Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 356 Forum
Old 10-03-2009, 02:42 PM   #1
MUSSBERGER
MUSSBERGER's Avatar
Default Its in
polo motor in little bros reutter
1981SC black metallic,no sunroof, departed.(bonehead move)
2004 Cayenne, base, departed.
2005 987S Boxster, guards red, Stuttgart built, departed.
1978 SC E track car.
2005 997 black, pollen magnet.
MUSSBERGER is online now   Reply With Quote
Old 10-03-2009, 03:34 PM   #2
Todsimpson
Todsimpson's Avatar
Seriously cool...
Todd
'71 911T 3.2
'69 2800CS 3.5
Todsimpson is offline   Reply With Quote
Old 10-05-2009, 07:05 PM   #3
guydawger
guydawger's Avatar
I want one!!!
guydawger is offline   Reply With Quote
Old 10-05-2009, 09:06 PM   #4
MUSSBERGER
MUSSBERGER's Avatar
Quote:
Originally Posted by guydawger View Post
I want one!!!
Who let you in?
Old 10-05-2009, 09:27 PM   #5
guydawger
guydawger's Avatar
I decided to bug my older brother and tag along, just like when we were kids lol.
1979 911SC. sport seats,factory 7s & 8s-gone but not forgotten
1989 930-cab. 12 plugs & injtrs motronic & inj ctr 1.2bar 500hp
1962 356B twin plug nikasil 92mm 10.5/1 comp 44 wbrs 140hp
1953 Ruetter Coupe w/911 susp bxtr brakes Polo 930-4 2.6ltr
Old 10-05-2009, 09:55 PM   #6
MUSSBERGER
MUSSBERGER's Avatar
This is what everyone is waiting for. And on the 911 board as well. Tell Dean to hurry up. Hi Sam.
Old 10-06-2009, 01:11 AM   #7
ked
ked's Avatar
neat!
ked is offline   Reply With Quote
Old 10-06-2009, 05:18 PM   #8
bleucamaro
bleucamaro's Avatar
That is a cool setup,
let me rephrase: That is WAY cool, freaking beautiful!
It seems like info on it is pretty hard to come by. I saw a thread on pelican and 911S about it, but it seems the info posted contains alot of hearsay. Even the APV website only mentions casting the case, and custom crank, cam, and oil pump drive, with no mention of heads or cylinders (or any other internals).
Guydawger, Is there anyway you could share what you paid for that motor (so I know whether or not I should nut-punch myself) over the cost of our 1883. (I know, i know, a bit rude to ask)
sold:1989 944S2, Baltic Blue / Linen
2005 STi, WRB
1960 356 S90 Project Car
WTB: clean 911 SC, 3.2 Carrera Coupe, pre '75 911, C6 Corvette, 2010 Camaro or house.
The Better Place
bleucamaro is offline   Reply With Quote
Old 10-07-2009, 03:17 AM   #9
guydawger
guydawger's Avatar
For now I can only tell you what the kit costs which includes as you saw, the case, the cams, the crank and the oil pump drive. 13000.00. And I know for a fact that there is only one kit available right now and it has the 3.6 90mm head stud pattern which builds to a 2.4 to 2.7 liter. And Weber 48s are the only choice on top. The good news is that its all Porsche stuff which is the cheap stuff lol. My motor has some nice titanium rods in it as well which is sorta high on the cool list. Whats the build sheet of goodies look like on your 1883? I know my twin plug C motor thats in my 62 could buy a 10 footer 356 driver and I often think of nut punching my own self hahaha.
Old 10-07-2009, 05:06 PM   #10
bleucamaro
bleucamaro's Avatar
Our 1883 build sheet looks about like this:
LN Engineering Cylinders
LN spec. JE forged pistons
ARP hardware
Super 90 case
Super 90 crank
Nutech SX2 cam
Super 90 heads
Larger valves
Ti retainers
New valvesprings
Full flow oil conversion
EFI conversion (still in process)
Competition Engineering did all the machine work.
With yours, did the kit also include cam housings and cams? What about the cam covers? I’m assuming it uses custom machined cams as well? Is all the sheet metal custom, or did the factory stuff fit? What about the fan shroud?
2005 STi, WRB
The Better Place
Old 10-09-2009, 03:28 AM   #11
guydawger
guydawger's Avatar
Your 356 motor sounds like a good one.What size nickies did you put in. I used 92mm nickies in mine and they run super cool even in 110 degree traffic. Your build sheet looks very close to my C motor thats in my 62 B. The only thing I would reconsider if its not too late is the S90 crank which is your probable weak link. I assume you are twin plugging the heads.
The factory 911 tin fits beautifully with about 1" or so cut off each side. fan shroud from 64-87 works and the cam covers can be 1978 thru 1992 4 bearing type and just shortened to fit. The cams come with the kit. I drove an A car with this motor in it and it was the coolest car I ever had the pleasure to drive. The sound, the close ratio gearing and the ride all made for a thrilling experience. My 53 now has 911 suspension, Boxter brakes and on and on. We lack the oil lines, the custom Bursch exhaust system, foam in the fuel tank and roll cage. So close......................
Old 10-09-2009, 03:16 PM   #12
bleucamaro
bleucamaro's Avatar
We are using the 90mm, and as for the crank choice and whether or not to twin-plug, we went back and forth on it. The S90 crank was inspected, and is flawless. A benefit from EFI is that we can set a soft rev limiter where ever we want, and will limit the revs to ~6000rpm. Another benefit is the precision of spark delivery, this swayed us away from going twin-plug.
Who's fuel tank foam are you using. That is something I wanted to do, but never looked that far into it. Are there any problems with deterioration and clogging filters?
2005 STi, WRB
The Better Place
Old 10-29-2009, 03:37 AM   #13
guydawger
guydawger's Avatar
Hey Bleu,
We are going with Fuel Safe for the foam. No problems that Ive heard about as its the same stuff they use in fuel cells. you lose maybe 8-10% of your capacity but it makes the tank much safer and keeps your load steady. The twin plug really is the ideal compromise unless your only going 9.5/1 or less compression. My car is at 10.5/1 and with the Nickies and the twin plug heads runs very cool even on hot summer days in So Cal traffic. As far as a limiter goes, your motor will tell you where it wants to rev to. Sounds like your all in on this motor lol. My brother Mussberger always says, which part did you think was going to be cheap, the Porsche part or the race part?
Tags
911, gt2, guards, red
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
