356 Forum 1948-1965
Grinding starter
Old 11-01-2011, 12:38 AM
wesmc3
wesmc3's Avatar
Default Grinding starter
First start-up of a 1960 356b...car had been dissassembled for paint when I got it but I was told it was a driver.
Converted to 12v.
Starter grinds badly when key is hit.
Took starter and solenoid are and tested them. They test fine.
Starter is 6v, solenoid is 12v.
This would be what I would expect to find.
Is it common on the 356 to change to a 12v ring when changing to a 12v system? Is there much chance I am sticking a 6v starter against a 12v ring?
Anything else that causes these to grind when engaged?
Sorry for knowing so little
Old 11-01-2011, 11:58 AM
Steve Jensen
Steve Jensen's Avatar
The teeth/gears/engagement surfaces on the flywheel and starter are different between the 6v and 12v versions... dropping the engine will only take an hour for your first try.. I'd look at the flywheel and see if grinding is obvious... or remove the starter and check there...
Old 11-01-2011, 01:19 PM
wesmc3
wesmc3's Avatar
thanks...I am kinda flying blind with no real history on what was done or what conditions it was "driving" under.
Old 11-26-2011, 04:37 PM
wesmc3
wesmc3's Avatar
Replaced the solenoid with a new unit, cleaned and lubed the starter, problem solved.
Old 10-09-2012, 09:06 PM
Edgy01
Poseur
Edgy01's Avatar
Stoddard has a good deal on 6V starters right now.
Quick Reply: Grinding starter
