Paint correction on Chalk GT4?
My Chalk Spyder had a few imperfections/swirls that were easily corrected. As mentioned above it's a great way to know your car. Enjoy!
Premium Sponsor
I got the car on Wednesday, it looks good under my garage fluorescent lights but with my scan grip light you can see some light maring and swirls that you’d expect from a dealership prep wash.
I have the full range of lake country force hybrid pads and a selection of polishes:
M105/205
somax perfect finish
CarPro reflect and essence
3D HD Adapt
Menzerna FG400 and I think a 1500 and 4000 grit as well
The last touch up I did on my M3 I used M205 with a stiff cutting pad and it worked really well. I think I saw that tip on Larry Kosilla’s YT.
M105/205
3D HD Adapt
it’ll be a little tough to get the most refined finish with the flex since it’s forced rotation, but we can make it work
ideally you’ll want a porter cable or Rupes to go with the flex
for most DIY, Rupes is sufficient for like 90+% of imperfection
Specializing in Porsche/Ferrari since 1995
Why choose GP...WATCH OUR DOCUMENTARY
Follow Moe HERE
GP Fastrak - Ceramic/PPF/Tint in one simple bundle - Click Here for more info
Follow Moe HERE
Could I ask a related question.
I picked up my Miami Blue GT4 in December. With the weather so bad I have not used it much but was able to wash it recently for the first time.
I noticed very light scuff marks (it looks like someone rubbed something against the car) in the area between the rear wheel well and the hatch (the horizontal part of the quarter panel in front of the wing).
It is very hard to see and even knowing it is there you can only see it from an angle. If you look straight at it you can not see it and it can not be seen in photos even when trying to take a picture of it. Also, if you run your fingers over the area you can not feel anything.
I ordered finishing sealant from Griots Garage as it is the least aggressive polish they have, and the recommended black pad.
I plan to do this area by hand. Will I then have to do the entire panel?
If anyone has any tips or suggestions I would greatly appreciate the info.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
This was the state my 15 mile brand new chalk paint was in. The GT4 was a COVID orphan sitting in the showroom for a couple of months. The dealer washed it (water spots) and probably removed dust multiple times (swirls). The car was shipped from Amsterdam to Alabama afterwards. I compounded and polished the car myself using Sonax profline cutmax and perfect finish icw the Mequiars microfiber pads. I used a cheap Harbor Freight DA polisher because I can’t use 110V tools back in Europe. Don’t want to invest in expensive tools I can’t take with me. Works fine but it took me 5 days to get everything done including 3 layers of ceramic coating.
The video shows before and after compounding.
My Chalk paint has quick a few swirls and lines from the transport wrap. Had to do a professional 2 stage paint correct before PPF and Ceramic on top.
https://youtu.be/JjJDsSmx5cc
