Android Auto
Android Auto
Forgive my ignorance but I'm trying to understand connectivity options.
I currently use an android phone. What functionality should I expect in a GT4? Will my phone pair with the car via Bluetooth? Is android auto possible or do I need to do this aftermarket? Is there any benefit to choosing apple car play if I have to add Android Auto later?
Bluetooth, yes. There's no android auto out of the box but it can be unlocked in the PCM via some hacking/trickery. Requires buying a particular kind of cable and paying someone far away to remote into your laptop so they can unlock the feature. That was the procedure last time I checked anyway.
iammacey (01-27-2022)
drive95 (01-28-2022)
Android Auto can be enabled after purchase and does not require CarPlay be specified in the build, these are separate features within the PCM. However as mentioned AA is not offered by Porsche even though the firmware is already in the PCM, it has to be enabled by a third party. I have this done in my Spyder and full AA functionality is available when you connect your Android phone via a USB cable.
HTH
There is a guy, sima on 718forum who does this for $150. Needed to buy a cable and then he remotes in. I was concerned in the beginning, but worked like a charm. I think he said he works for Audi and the code in the PCM is the same and he just unlocks it. I now have an iPhone (apple carplay was optioned on my car), but turning on Android Auto was great - Highly Recommend. You definitely want to option Apple Car Play as its a must for resale...
Just do the Android Auto changes yourself
tinyurl.com/yt2ydmmt
You can also add NAV and GPS while you are there
shorturl.at/hqyR3
shorturl.at/hqyR3
dnimi123 (01-28-2022)
@simaservis1108 Sima did mine as well, I have no hesitation recommending him for the task.
I will grab a shot of it at lunch time...
MaddMike (01-28-2022)
So here is the screen that you launch from, as you can see no device is connected to the USB in the car, below that I show a close up of the icon change:
The following 2 users liked this post by Westcoast:
lowbee (01-28-2022),
Spike Spiegel (01-28-2022)
