Any significant differences between Tarett and TPC toe links
I am planning on having an alignment done and figure I might as well get toe-links as well. Both TPC and Tarett are highly regarded. Other than the “pinch” locking mechanism on the Tarret, is there anything that sets these toe links apart from each other?
Thanks on advance
Thanks on advance
Going from memory when I shopped a year or so ago: Tarett has the cool pinch locks, TPC doesn't (uses jam nuts), TPC has the cool offset inner monoball, Tarett doesn't. Back in the day, Tarett used generic language for the front and the rear about the bump steer reduction, but it applied only to the front. Might also be a difference in the spindle end, but don't have that one in my memory.
I went Tarett for my fronts, TPC for my rears, both work great so far.
I choose the Tarett motorsports version one because that is what my race shop recommended because of that pinch locking mechanism.
One of my questions was, well the TPC one as the off-set for less dynamic toe change. I have quarried both my race shop I use and Tarett directly and asked that question and I have been told by both that the Tarret motorsport version indeed has that feature as well. Some say the Tarett morotsport version does not have that feature, others say it does. Which is accurate, I do not know.
I will say that with my MCS suspension set-up and my compression/rebound settings, I can stomp on the brake mid-corner and the rear does not want to come around at all and in a straight line it feels stable standing on the brakes. Having said that, it I loosen up the compression/rebound settings some, the rear does become more lively. I can't say which is better for stock suspension though. Also of note is that I am also running 2.2 mm per side toe-in, for a total of 4.4 mm for my rear toe setting.
Underblu (11-01-2022)
I didn't see the offset feature. When I queried Tarett back in the day, they said it was a copy paste from the text in their front tie rod listing, and the fronts do have a different offset for improved bump steer. I don't see how a different offset is generated with their rears. That said, prob won't make a gigantic difference in handling if you dial in the forum recommended toe.
Yeah, I was a little suspect too, since there is no obvious design feature that you can see visually that would suggest there is any off-set there. In either case, for me it is a non-issue as I have aftermarket suspension and have it dialed out with springs and damper settings. I am not sure if anyone has done back to back testing of both units on stock suspension though.
Part of the issue IMO is the stock PASM's under damped rebound control. In either PASM suspension settings, the stock damping just does not control the rebound stroke well enough, so you get a large extension when you encounter bumps that raises the suspension , thus more toe change. Obviously though, that is road dependent.
I have the TPC toe links. Couple of things. With my 19x11 with 50 mm offset wheels I still have to run a 5 mm spacer to clear the toe link. As far as the rear wiggle, I still have to concentrate on being smooth or I will still get the wiggle.
The offset inner ball on the TPC toe links is quite visible and obvious. On my otherwise stock Spyder, I could immediately feel the improvement in rear end stability under braking with the offset toe links, even though I stayed with a near stock alignment initially. However, while the TPC toe links clearly reduce rear bump steer, it’s still possible to get a little rear wiggle under hard high speed braking on track, at least with the 12 minutes (0.2 degrees) per side of rear toe in I’m running. I’m talking about maximum braking from above 230 km/h on track, I haven’t triggered any rear wiggle anywhere close to street speeds. Perhaps increasing the rear toe-in further could fix this.
Larry Cable (11-02-2022)
Curious if these little green bumps for rear axle slip show moments when the rear is wiggling. (This is using the track precision app)
I notice inconsistent rear wiggle when braking from high speeds on the track. Haven't seen it on the street since installing the toe links, but I never brake that hard on the street either.
.04" toe in per side in the rear
urious
urious
urious
urious
If you know when it wiggles it would be cool to see what the data shows. Unfortunately I don't know on which laps it occurs and I stopped caring about it so I'm only guessing
Underblu (11-02-2022)
Anyone know if there's a difference in clearance to the wheel between the two while running 19in wheels? I've seen anecdotal accounts of needing either spacers or shaving some parts.
Edit: Should add that for my 19" wheels I'm running standard Cayman sizes & offsets (i.e. with rear @ 19x10 ET40), so for those running wider wheels / different offsets, YMMV
