Oil Change on GT4RS
#106
Also can someone verify if there is restricted space for tightening the secondary oil tank “end cap” plug (as with the main/pan drain plug)?
I am looking to determine if there is adequate space to utilize the Klein tool with handle which I posted in the previous post (for the purpose of turning the plastic oil tank plug).
Thank you.
Thank you.
#107
@matttheboatman
@GrantG
@Hoosier Daddy
@Ksdaoski
Others
Thanks again everyone for all the information in this thread.
Does anyone have the tightening torque specification for the engine oil filter part #0PB115351? Does anyone have the corresponding Porsche document referencing it which could be posted?
Obviously the filter is tightened to around 16 ft-lbs and hand tight, but I was wanting to be precise on this for a reference guide I am working on.
@GrantG
@Hoosier Daddy
@Ksdaoski
Others
#108
It shows 20Nm (15 ft-lbs) right on the filter same as workshop model manual):
#109
If you have a friendly dealer, they can help. Otherwise, I think there is some portal where you can pay by the hour (I think you need prior approval and have a business, which I don't)
Also, a Rennlist member had luck at this site once (for another model). Here is GT4 RS link (no idea if it's working properly):
https://cars-technical.com/product/p...iring-diagram/
#112
Webpage for request is:
https://pcss-tsi.porsche.com/landing...ion?country=US
Change your country if applicable.
GrantG (04-24-2024)
#115
Hello there, sorry about the time lapse here but have been away for a while, will try to answer as best I can.
1. I believe I added oil 3 times, the 4th jar as I remember was a sample taken from the last and 3rd flush, ie loosened the plug to get a sample then tightened fully, used a total of approx 12 litres of oil.
2. Yes I think at least 1 flush would be beneficial, 2 obviously better if possible.
3. I think I actually left the rear hatch open all the time, however not 100% sure with my memory what it is, I do remember it took quite a while to get a reading as it only appeared once the engine was up to full operating temperature as you mentioned. I just basically put in the same amount that came out and it was always on the money.
Hope that helps.
Hope that helps.
#116
@matttheboatman
@sandy59
This thread is great and thank you for the jar experiment!
<sandy59> —
I would like to ask you to clarify a few things, please:
1) I observe that you’ve mentioned three flushes; and I hope I am correct to observe that four jars of oil that were extracted with the fifth jar representing virgin oil. Do I therefore interpret correctly that you added oil a total of 4 times?
So that’s drain then add then drain (flush 1), add then drain (flush 2), add then drain (flush 3), final add?
2) If yes, it seems those of us who wish to follow suit would benefit from your experience by flushing only twice (3 total additions) — do you concur?
3) My experience with recent Porsches in general (992.1, 991.2, 981) — and more specifically to this discussion, with my 718 Cayman GTS 4.0 and also my 718 Boxster GTS 4.0 — is that the gods of Porsche oil level display do not want to allow a display of oil level if the rear hatch has remained open for any amount of time more than about a minute; it takes a while for oil the level display to reappear. I do not have the Porsche computer but I’ve worked with someone who has it and if using the computer through OBD, this is not an issue. I am assuming you were not using the computer during this procedure.
(a) Can you comment on this phenomenon of oil level display lockout as it relates to your procedure of refilling and checking / making additions to the oil level?
(b) Were you able to see an oil level display all the time during this process, or did the display at first say “No oil level information available at present” for a duration of time while idling and then the level suddenly appeared when the engine was just about warm? If applicable, is there a trick to prompting the system to display the oil level immediately?
@sandy59
<sandy59> —
Hope that helps.
#118
I have found the GT4rs oil reading is a lot quicker and has a "path" vs my 991.2 3.0 which seems random....
Pretty much, close the hatch, start the car and let it warm up to 170 or 175 degrees, on level ground, then check the oil level. It will then run through a 2 minute countdown on the gauge, and then show you the oil level once the 2mins is up. Have to be at a standstill for the reading, can't be driving.
I don't remember the actual temp, but it will tell you if it's not warm enough. And I believe it's in the 175 range. It's prob 80 degrees Celsius which is 176....
#119
Thank you.
So in other words, the GT4 RS is much more lenient than the normal cars with the “No oil level information available at present” message which on the normal cars (991, 981, 982) takes a really long time to go away?
Ksdaoski (04-29-2024)
#120
@Ksdaoski
Thank you.
Thank you.
I dont recall if it's in the owners manual. But I spent too much time on the False Grid at Road America waiting to go on track this past year, messing around with the gauges, as I learned about the track tire pressure settings and then trying to check the oil level. And was able to repeat it at will, everytime. And if one of the requirements is missing, it will tell you when you're checking...."not at operating temp" "must not be moving" "wait 120s for oil level". Something to that effect
348SStb (04-29-2024)
