GT4/Spyder Spark plugs
https://www.suncoastparts.com/produc...18gtplugs.html
https://www.hazet.de/en/products/spe...-4000896087655
Basic Sponsor
Here are the plugs. Never did them on my GT4, but have done several times on 991 and 992 GT3 and it’s easy (get the Hazet socket recommended in the Workshop Manual). And hhis is the one for GT3 at bottom (not sure if GT4 is same not):
Leaving the issue of ultra thin spark plug socket aside, the spark plug job on 718 4.0 engine overall is quite a bit more demanding than on a GT3. You need several 3/8" extensions of various lengths and a swivel joint. Then also either a 3/8" torque wrench or a 1/2"->3/8" reduction to use with your 1/2" torque wrench (set to 32 Nm).
If the Hazet indeed is 18mm and not a hair thicker, it might, but only just might work. It's been proven in my thread the OP has been linked to in the other thread he recently started, that 18.4 mm is too thick for this job.
911T4ME (04-21-2024)
Basic Sponsor
The thread can at least save you the trouble of undertaking the same journey and you know, that anything thicker than 18 mm will not work.
I tend to believe Porsche designed the spark plug holes like that on purpose (as the coils do not have an aftermarket alternative either and you have to buy them from Porsche). Seems like they don't mind making sure the Major maintenence is done at Porsche dealerships (just like tyre jobs on centerlock cars).
As more and more 718 4.0 cars keep coming up to the 4 year mark perhaps someone would come up with a suitable socket like the Duralast #72-376 mentioned in the thread, which was 17.8 mm, but unavailable to buy.
NutCracker: Because everyone should be able to swap a wheel on any passenger car!
2014 981BS (sold)
2020 718 Spyder
2018 991 GT3T
2014 981BS (sold)
2020 718 Spyder
2018 991 GT3T
maschinetheist (04-22-2024)
Can anyone post this for 718 GT4?
It does also seem that spark plugs are not available easily from makers like NGK. Has anyone found an alternate supplier for plugs?
GrantG (04-22-2024)
I found this:
https://ctatools.com/products/2376
Its O.D. is 17.90mm. If that's true, this may be able to work as well.
GrantG (04-23-2024)
https://www.amazon.com/WORKPRO-Magnetic-Swivel-Socket-Enhanced/dp/B0BBFL5QRV/?_encoding=UTF8&pd_rd_w=OBcfr&content-id=amzn1.sym.dde481d7-92dc-42ce-a703-f1bc175e21c6%3Aamzn1.symc.d10b1e54-47e4-4b2a-b42d-92fe6ebbe579&pf_rd_p=dde481d7-92dc-42ce-a703-f1bc175e21c6&pf_rd_r=87JYZ6K50CFAKZ8TBPVC&pd_rd_wg=YGMOV&pd_rd_r=290ec7dc-703d-4846-8b94-a76dea7c5ba5&ref_=pd_gw_ci_mcx_mr_hp_atf_m&th=1
Would this work?
You will need various extensions to do the job, so if you don't have many, this kit may be useful.
delete
