911 Forum 1964-1989
New problem
Old 08-02-2017, 08:28 PM
iFox
iFox's Avatar
Default New problem
Ok so a bunch of you know I had my 78sc in for a leaky tension upgrade job. While it was back I also had the trans fluid and oil changed. The day I picked it up as I placed it into first gear there was a momentary grind that never happened before. Wasn't sure what was going on and since the Then I have had it happen 6-10 times while going from N to 1st. I thought it was maybe that the new trans fluid. That was last week. Today on my way home 4 blocks from home I could not get it out of 2nd or into any gear with out severe grinding. It is now in my parking spot. I can shift it fine with clutch depressed while car is off but it won't go into any gear with it running . Thoughts? Car shifted great before shop visit.
Sher
Old 08-02-2017, 08:34 PM
Amber Gramps
Amber Gramps's Avatar
Stretched clutch cable. .....masked by the old thick oil now gone.
Old 08-02-2017, 08:37 PM
iFox
iFox's Avatar
It smelled too when I parked it. Also reving the engine in neutral seemed funny. All part of a stretched cable ? Could I have done damage? Is this an inexpensive repair?
Sher
Old 08-02-2017, 08:42 PM
Amber Gramps
Sher
That smell is another clue that it's clutch related. I don't think it will be too costly unless you completely lost the clutch.
Too loose you have problems opening the clutch and too tight and you never get it to clamp down. Take it back to the shop.
Old 08-02-2017, 08:45 PM
iFox
iFox's Avatar
definitely flat bed it to shop though correct?
Sher
Old 08-02-2017, 08:56 PM
Amber Gramps
Sher
Yep. Sucks.
Old 08-02-2017, 08:58 PM
iFox
iFox's Avatar
Yep. Sucks.
yup it def does Thanks for the advice My garage is UNDER the building I live in so now I have no idea how to get it out. Ideas?
Sher
Old 08-02-2017, 09:23 PM
iFox
iFox's Avatar
Would it be dangerous to shift into gear w car off then start it to get it out of garage to flatbed?
Sher
Old 08-02-2017, 10:45 PM
rusnak
I haddah Google dat
rusnak's Avatar
I wonder if someone got oil somehow onto the clutch disc?
You can shift it into first with the engine shut down, and then turn the key on level ground. The car will roll forward and if it fires up, then you'll be able to drive it out. If you need to stop on the incline, then you're screwed. Mabe see if the tow truck cable can reach the car down the ramp, or use a smaller 1-ton tow truck.
Old 08-02-2017, 10:47 PM
911Dave
911Dave's Avatar
How many miles on the clutch? Is it original? If it's original, the SC had a rubber-centered clutch that is prone to failure. Was it a rubber smell? Grinding almost always points to the clutch not fully disengaging. If you get the clutch replaced, make sure the shop replaces it with a spring-centered one.
Old 08-02-2017, 10:53 PM
iFox
iFox's Avatar
40k miles. Amber gramps seems to think it is my cable though. Amber, can it be moved safely?
Sher
Old 08-03-2017, 04:06 AM
proporsche
proporsche's Avatar
Hi iFox...what i like to know since the shop did trany oil change and before you never had a problem with shifting.Did the problem started after you pick the car up?
Yes you can start the car in 1st gear but you have to make sure where you will be going and where do you want to stop.Nothing in the way..
I would most likely call the shop and let them deal with it.
Again, did it happen right after you got it from them?I wonder if there is the oil in the trany???
Ivan
Old 08-03-2017, 12:10 PM
911Dave
911Dave's Avatar
Sher
What function does the clutch cable serve? To disengage the clutch. If the cable isn't doing this properly, or if the clutch itself is the problem, you get grinding. That was my point.
Old 08-03-2017, 12:34 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,049 Likes on 746 Posts
yeah id be wondering if they remembered to put fluid back in.
if they " adjusted " the clutch while they were under there they could have messed something up
.. all this aside id say its time to find a new shop.
Old 08-03-2017, 12:40 PM
Amber Gramps
If it we're not for the smell I'd say it was the oil viscosity.
Quick Reply: New problem
