911 Forum 1964-1989
New Product: Steel Porsche Hub Stands for 911
Old 09-06-2017, 01:24 PM
Carl Fausett
Developer
Carl Fausett's Avatar
Default New Product: Steel Porsche Hub Stands for 911
Description: A commercial-quality tool that belongs in every serious Porsche shop owner's garage. Better than jack-stands, makes working on your car more enjoyable, safer, and faster. Made in the USA, each all-steel hub stand weighs 18.5 lbs. and is professionally painted in a chip-resistant and durable semi-gloss black powder-coat.
As a Replacement for Jack Stands:
  • More secure than jack stands - screwed on - car cannot fall off the hub stand.
  • Places center of hub 18" off the floor. High clearance for ease of working under the car.
  • Supports the weight of the vehicle where it was intended to be supported.
  • Great for winter storage of your car, prevents flat-spotting of tires.
  • Not in the way of creepers like jack stands are.
  • Designed for vehicles up to 5,000 pounds.
Fitment: Fits all cars with a 5 X 130mm bolt circle and a hub diameter of 71.5mm or less, including:
Porsche®: 911, 918, 944, 928, 968, 996, 997, 980, 991, Boxster, Cayman, Cayenne, Macan, Panamera
Audi: Q7
VW: Touareg
Pricing: is per PAIR at $264.70
To Order:
https://928motorsports.com/parts/hub_stand.php
Old 09-06-2017, 07:03 PM
rusnak
I haddah Google dat
rusnak's Avatar
I can't read the first post. Too many fukking pop up ads blocking it. If it does not register in the hub, then weight is supported by the studs, not the hub. The studs do not support the weight of the car in normal operation. The hub does.
Old 09-06-2017, 11:20 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,049 Likes on 746 Posts
Looks like a lot of money for a pain in the *** setup
Old 09-07-2017, 02:52 PM
Felix
Rennlist Lifetime Member
Felix's Avatar
They must need to be able to slide as the suspension settles after jacking?
Old 09-07-2017, 03:14 PM
Carl Fausett
Developer
Yes, and they do.
Old 09-07-2017, 05:33 PM
Felix
Felix's Avatar
Assuming you have a nice smooth concrete surface to work on?
Old 09-08-2017, 03:24 AM
ADias
ADias's Avatar
Not practical for changing rotors and suspension elements.
Old 09-08-2017, 12:38 PM
theiceman
Team Owner
theiceman's Avatar
Has an amazing cool factor though !!!
Old 09-11-2017, 01:04 PM
Carl Fausett
Developer
Which you could say for any hub stand, jack stand or floor jack...
Old 09-11-2017, 01:07 PM
Carl Fausett
Developer
True. For those projects, you would like your suspension unloaded.
But there are many projects in the wheel well where you would like better access to the suspension adjustment points with the suspension LOADED, like an alignment. Or maybe just because you want more creeper room under the car without kicking jack stands all the time. Or maybe because you want to store your Porsche for the winter without flat-spotting your tires.
Quick Reply: New Product: Steel Porsche Hub Stands for 911
