3.2 Cold Run Issues
Thank you Loren.
Everyone I know in the business locally uses Loren for all things Bosch.
Any common cause come to mind as to why I need to leave the key in the ON position for 5+ seconds before hitting the starter?
Man, my board looked WAY worse than that. Like water damage bad. But alas, it's already been sent off to see if can be repaired, and my core charge refunded . . .
So, where did you end up sending your DME repair? I am in a similar situation. My mechanic borrowed a good working DME and the car ran great, no issues. So we will send mine out for repair. I have an aftermarket chip in there now but would like something better. Who is Wong and Steve, some posts referenced chips from them. Let me know the best rebuild. Fast, Fast, Fast!! (speed)
True, but read through the info on 911Chips site. Gives a good overview of what can go wrong with just age and wear alone. Mine may have had water damage at some point, but many of the soldered connections were just shrinking in cold and expanding once up to temp. Just from age, best we could tell.
That's not true and misleading. It takes over 350 degrees F to begin to melt solder and/or to affect the circuit board connections.
Actually read here: http://www.systemsc.com/problems.htm ; under Porsche, DME ECM which provides data from over 25 years rebuilding those ECMs.
No path-leading intended on my part. Just sharing my experience. I am the last person anyone should take technical advice from. I defer to those with substantially more experience and know-how than me.
Then when the ECU is returned "rebuilt", the rebuilder says it needed to be rebuilt anyway, because it was going to fail in the future. And for you or your mechanic
to continue to find the real problem. Great way to do business, right?
