911 Forum 1964-1989
Clutch Job
Old 01-27-2018, 06:30 PM
PerryB
PerryB's Avatar
Default Clutch Job
Hello all,
I am about to do my first clutch on a 911. It's a 1986 Carrera Targa. I would also like to replace the synchromesh rings. Everyone says to pull the engine. Why can't I just drop the transaxle?
Thanks!
Perry
Old 01-27-2018, 06:46 PM
GTgears
GTgears's Avatar
Because it is pinned in place behind the engine.
Old 01-27-2018, 07:55 PM
PerryB
PerryB's Avatar
GTgears, thanks for responding.
You mean Pinned in front of the engine? Pinned how? Even with the engine out, how do you then remove the transaxle?
Perry
Old 01-27-2018, 08:15 PM
GTgears
GTgears's Avatar
I mean the studs holding the engine and gearbox are too long to push the gearbox forward and off them. Plus the shift rod extends into the tunnel. So you drop gearbox and engine together as an assembly. Then you split them on the ground. Lets you seal top engine leaks at the same time and do some detail work.
If you want to just drop the engine you can. The clutch will stay on the engine. But if you are going to do synchros in the box there is no point. It is a few hours at a casual pace. When I did it often i could do it in an hour with a lift.
Old 01-27-2018, 11:40 PM
old man neri
old man neri's Avatar
I'm going through something similar with an 88 (different transmission). I dropped the whole thing. It gave me a chance to do other things. Be careful, the 'while you're in there' list gets expensive real quick. Seals, fuel lines, brake lines, suspension bushings, engine mounts, flapper boxes, clutch fork, bearings, oil tubes.....etc.
Old 01-29-2018, 05:46 PM
PerryB
PerryB's Avatar
Thanks to all that replied. I'll get started soon and I'm sure I'll be back with many more questions as the job progresses.
Perry
Old 01-29-2018, 10:35 PM
GTgears
GTgears's Avatar
If you don’t have any manuals buy a copy of WAYNE Dempsey’s 101 projects book. It has enough detail to get you through the job.
Old 01-30-2018, 09:22 AM
old man neri
Bentley manual for the carrera is very good as well.
Old 01-30-2018, 09:52 AM
Amber Gramps
Amber Gramps's Avatar
Matt, where the €¥^✓¢∆! have you been?
You vanish for NINE YEARS with the world's coolest car and then just wander back in without any fanfare?? No way. Where is Murphy's car?
Old 01-30-2018, 12:03 PM
old man neri
The car spent a few years with me in a place called Newfoundland and now it's still with me in Halifax. It's currently in pieces in my garage getting the clutch changed among other things just like the OP.
Old 01-30-2018, 02:11 PM
Amber Gramps
Still a fly boy?
(I had a different user name back then)
Old 01-30-2018, 09:35 PM
old man neri
Still a fly boy?
I don't want to hijack. PM'd.
Old 01-30-2018, 11:01 PM
GTgears
GTgears's Avatar
I was thoroughly confused because I too am Matt and Amber knows the status of my car.
Quick Reply: Clutch Job
