911 Forum 1964-1989
Adjusting brake pedal height
Old 01-27-2018, 10:53 PM
_Remi
_Remi's Avatar
Default Adjusting brake pedal height
Hi friends,
I tried to adjust the brake pedal height on my 1993 964 and I got stuck pretty quickly. Removing the carpet and wood board was straightforward, here's how it looks:
And here's why I am stuck: I understand that I need to adjust (B) to be able to control the brake pedal height but when I loosen it up, it moves freely and does not do anything. I then tried to free the pedal and there's the (A) piece (no idea what this is called) that prevents me from doing anything. This is a poor explanation but that's the best I can do
Also, any tip to reconnect the accelerator pedal once the wood floor is back on? I manage to do so with pliers preventing the hinge from going down but that did not feel right.
Thanks a lot!
Old 01-29-2018, 02:31 AM
Amber Gramps
Amber Gramps's Avatar
Maybe if you went looking for help in the 964 section you'd get some help.
Old 01-29-2018, 10:04 AM
Amber Gramps
Ok, I was a bit harsh. Try pulling the clip you marked as (A) then slipping the Heim joint off the end. You can then loosen the jam nut and adjust the Heim in or out.
The gas pedal just needs a little pressure to put the ball back in the socket.
Old 01-29-2018, 01:40 PM
_Remi
_Remi's Avatar
I thought I was part of the big 911 family
Thanks for the instructions, I now need to find a way to remove that clip without breaking it. I tried a few times, no success but I'll give it another shot later this week
Old 01-29-2018, 03:35 PM
r911
Anti-Cupholder League
r911's Avatar
to reconnect the accelerator pedal once the wood floor is back on, clamp vise-grips on it; lube ball end and recess with soapy water and jam on it hard
Old 01-29-2018, 05:32 PM
oldskewel
oldskewel's Avatar
Agreed. And the first two steps may be considered optional.
I recently had this all apart on my '85, where for no particular reason, I replaced all the bushings, and re-painted the wood black (as it was originally on my car).
Mine has the older cable-actuated clutch.
Old 01-29-2018, 09:12 PM
Amber Gramps
Looking at your picture of the clip you would first move the safely latch on the clip to the left to clear the pin then push it away from you to remove it from the pin. It's kind of a two step process. Pry out then push down.
Old 01-29-2018, 09:23 PM
Amber Gramps
Here is a good look at the clip style:
http://www.rmeuropean.com/Products/N0126452-MFG100.aspx
Old 01-30-2018, 11:55 AM
_Remi
_Remi's Avatar
Excellent thanks! I'll give it a shot this week-end.
Quick Reply: Adjusting brake pedal height
