911 Forum 1964-1989
External Voltage Regulator Location
Old 11-27-2018, 11:10 PM
Farmer
2nd Gear
Farmer's Avatar
Default External Voltage Regulator Location
I am trying to check out a charging problem on my '80 911SC. I have my voltage warning light on. I thought I would start by checking out my voltage regulator. Where is it located -- I assume it is an external VR. Thanks in advance for your help.
Old 11-28-2018, 03:06 AM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
The VR is built into the rear of the alternator.
Old 11-28-2018, 04:34 PM
Stevie 77 930
Stevie 77 930's Avatar
If you're sure you have an external regulator, it would be on the drivers side of the engine compartment next to the CDI unit
VR has the yellow tape
Quick Reply: External Voltage Regulator Location
