Tunnel fuel lines
Tunnel fuel lines
In my '89 Targa I have been getting a slight fuel smell in the cabin for several years. I tracked it down to the tunnel and see the fuel lines and other stuff run through this passage.
I have the engine/trans out of the car and wanted to address the fuel lines that run through the tunnel. I've done all the engine lines and they are clean.
Anybody done this? If so, what tips/tricks are recommended and what parts are ideal?
Thanks,
Scott
Thanks,
Scott
I haven't done this job myself, however there is a lot more information in the Pelican Forums about this. Also, look up Len Cummings (user is BoxsterGT) on Pelican forums, as he used to sell complete fuel line kits.
Are you sure it is the lines and not something else?
Those lines in the tunnel are a hard plastic and I’ve not heard of them leaking.
Now. The connection from hard to soft at the fuel pump yes. And in the engine bay the 4 fuel lines. Yes.
you may want to inspect your vent system and carbon canister system lines. Additionally, the filler neck rubber joint line is a common issue, they crack on the inside.
Lots of great info on pelican and suppliers for the lines. The trick is a coupler that connects the new line to the old so you pull from back to front. I pulled the fuel pump and front lines to make this easier along with the engine being out.
There are some bulkhead bushings in there holding the lines in place that you need find and free up to allow the fitting to pull through. Access from shift linkage and shifter hole in tunnel will help with that.
all in all not too bad just need to take your time and make sure you get the coupler. I did mine as a precaution while I was doing lots of other projects.
good luck
good luck
good luck
good luck
Yes, reach out to him at len dot cummings at verizon dot net. I have a set of his lines for my SC that I haven't installed yet. He's retired and he'll make them as ordered, so it may take a couple of weeks. He will also make the lines on the engine that can be a problem on the 3.2L cars.
Much tougher to replace the lines with the engine in the car, but doable. Len includes a coupler that let's you connect the new line to the old line - you pull the old line out through the front, and that pulls the new line in from the rear.
This is a good thread, but there are many others: http://forums.pelicanparts.com/porsc...ggestions.html
Mark
Mark
Mark
Mark
I read the thread you linked. The LEAKYSEALS951 guy is a fearless dude.
