Lowered too much?
Lowered too much?
Hey all,
I'm taking my newly purchased 87 Carrera into the shop to have a few things serviced. The car looks as if it was lowered TOO much. Maybe just lowered too much in the rear. It almost looks like it's slouching back. I have no idea what has been done to the suspension at this point. What are your opinions on this? I'm assuming some minor adjustments could be done fairly easily on these cars.
Hey all,
I have the same issue with my 1987 Carrera. Mine was purchased in Germany by the original owner. I believe it was set up at the European height which I think was lower than USA cars - not sure about that. I am thinking about having the height adjusted up as per USA cars. I had a 1986 Carrera which was set up with a slight rake from back to front. I really liked the look.
the only year where a Carrera was lower than a other models was '74, not couning specials like SC/RS or the like
Looks ok
Team Owner
personally i don't like them lowered like that and for me the car looks dated like that and reminds me of a 356.
To each his own though and i would not ask others on what looks good and not looks good to me.
How does it ride and drive? It looks great.
paddlefoot64 (06-06-2020)
This is all good feedback. Not what I expected honestly! The car drives and feels fine so it’s just a matter of aesthetic taste. The car is pretty much stock otherwise, so I don’t love the idea of an “after-market” looking stance. It’s really just nitpicking at this point though.
"when you measure, you know.." - Lord Kelvin
a quick measurement is at the fenders to gnd; more accurate one can be done as well
also use a bubble level on the door sill
are you htting the bottom on driveways?
The rule of thumb fender measurements to the ground are 25.5" at the front and 25" at the rear with stock 16-inch wheels and tires. That is "Euro", and should give you a slight forward pitch. Not totally accurate because the bodies can vary. The published factory ride height measurements are based on the distance from the ground to the center of the torsion bars and the ground to the wheel centers, but that is less convenient to measure.
Mark
Mark
Looks great. If it ain't broke, don't fix it.
Ralph3. (06-06-2020)
Team Owner
