Possible SW Chip issue in my 86 911
5th Gear
I bought a SW chip from Pelican and when I got everything apart, the pins don't line up. The SW is smaller than my factory chip.
What should I do?
Thanks for your help,
Ed
What should I do?
Ed
Your ‘86 should have had the 24 pin socket and apparently the DME was swapped out at some point with a newer 28 pin. SW has a 30 day return policy as long as it’s not a custom map. If you can’t return it let me know 😄
