911 Forum 1964-1989
1982 Porsche 911SC soft ticking sound when moving, not idling
Old 02-06-2024, 03:04 PM
francesconyc
francesconyc's Avatar
Question 1982 Porsche 911SC soft ticking sound when moving, not idling
I just noticed a ticking, of more of a flip flip flip, soft sounds that I can hear only when moving. it accelerates as the car goes faster and vice versa. it only happens when moving.
When idle, the engine sounds as it should for a 40+ yrs old. No strange noise. The previous owner had replaced gaskets, and valve covers I think, and it has always serviced the car with a lot of care.
At first, I thought it must be something to do with a rear tire tire because the frequency feels something that goes at the same pace as one cycle of the tire.
Can it be something to do with brakes? I even thought it could be something stuck on the tire.
Anyway, I'll try to make a video. I drove 200 miles and the car is great. And honestly, I don't even notice it anymore because of the engine's loud sound itself. but I'm curious to know my car better.
Old 02-07-2024, 04:29 AM
Vane
Vane's Avatar
Perhaps you find it, if you jack up each wheel and rotate by hand? When you find it, hopefully from one wheel, you can investigate further.
Old 02-07-2024, 10:02 AM
rowingone
rowingone's Avatar
Could be wheel bearings or even a stone in the tread.
Old 02-07-2024, 11:48 AM
francesconyc
yeah I haven't had time yet, but I will follow your suggestions that seems pretty easy to test
Old 02-07-2024, 12:35 PM
jfischet
jfischet's Avatar
i had an 82 SC for 18 years. i noticed what you're talking about a few times while driving slowly through the neighborhood. i think it's the odometer.
robtgreenberg (02-11-2024)
Old 02-07-2024, 01:36 PM
francesconyc
ooh interesting, I will keep an eye (or better ear) on that... yeah it feels very soft, and it blends with all the other louder sound when above 3,00rpm
Old 02-07-2024, 09:02 PM
GothingNC
GothingNC's Avatar
How are the CV boots, and how many miles are on the CV joints?
Is there any excessive play on the rear axles when the rear wheels are off the ground?
Old 02-07-2024, 11:10 PM
myflat6
myflat6's Avatar
There is a counter installed on the back of the speedometer that measures 30k mile increments to trigger the OXS replacement warning light.
jfischet (02-08-2024)
Old 02-08-2024, 04:36 PM
500's Avatar
This would be the first thing I would look at.
3,000 rpm is a fairly high threshold for drowning out of the sound. A few other preliminary things to "check" would be:
  • Can you hear this sound in multiple gears (i.e., first and second) and also reverse? Also, if you put the car in neutral and coast, do you still hear the sound?
  • Try to get a feel for which side the noise seems to be coming from, then swap your wheels left to right (assuming the tire treads are not directional) and see if that makes any difference
  • grab the top of each wheel and try to push it in and out firmly to get an initial indication of loose wheel bearings
Given that it is a soft sound, it is probably not a major issue yet, but it is a sound I have not noticed on my own '85, so it is probably something that you eventually want to solve.
Old 02-08-2024, 04:40 PM
francesconyc
Thanks for all the suggestions.
I'll try to troubleshoot this weekend. for sure it's not the engine in neutral/idle position even when revving, and pushing the throttle i don't hear it.
all the other suggestions around wheels, axles, tachometer or odometer (anything that rotates!) seem plausible
will keep you posted
Old 02-10-2024, 06:23 PM
francesconyc
UPDATE:
after driving today in a quite part of the city, and moving my head in different positions, opening windows etc
I certainly feel the noise is coming from the front/dash, not the rear or outside.
it does feel like a soft clock-y mechanical thing
I believe the Odotometer suggestion maybe a good one... which means I will get used to it and be fine...
jfischet (02-11-2024)
Old 02-10-2024, 09:10 PM
GothingNC
GothingNC's Avatar
Remove the speedometer and take it for a drive to see if the noise is still there.
Old 02-11-2024, 12:45 PM
robtgreenberg
robtgreenberg's Avatar
Default Odometer
I have the same issue with my 1982 911SC. My mechanic thinks that it is coming from the odometer but recommended turning the radio up a little. That worked!
Old 02-12-2024, 12:58 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,044 Likes on 743 Posts
lol exactly what i thought .. but i think you have to pull the wheel to get that out, be very careful doing this. Windshields are expensive.
Old 02-13-2024, 02:25 PM
Dr. 914
Premium Dealer
Dr. 914's Avatar
Coast with the engine off and see if the sound is still there, COULD be dry cv joints
Quick Reply: 1982 Porsche 911SC soft ticking sound when moving, not idling
