From H4 to LED headlights?
Hello, I'd like to brighten up my headlights without replacing the entire head. Mine are in excellent condition so I'd like to change just the bulb with an LED one.
I saw some YouTube videos and seems super easy.
is there a brand you recommend?
do they have to have the three prongs and some dimensions or can I use a model with a small fan like the Phillips Ultinon?
Anyhow, I know of lots of folks who have gone with the Philips and love them. I did it on my 964 and they work great.
Here's the Porsche version for reference - https://www.design911shop.com/p/bulb...he-pcg631134h/
francesconyc (02-09-2024)
to clarify, I forgot to state they are for a 911SC '82
wonder if they fit...
also note im in New York... im not even sure now if the Phillips are sold in US
You can get 7" Round H4 housings to replace your sealed beams for a very reasonable cost. This will retain the original look of your car but allow you to run the H4 LED replacements bulbs as referenced above. the other option is to upgrade your entire light assembly to the Euro 911 H4 assemblies, which is a considerably more expensive project, and will change the look of your car to the Euro headlight look.
either way I know what i have and i have Bosch H4
maybe the previous owner already changed them in the past.
Regardless, if you have H4s on a US spec car they have been changed in the past, and you are good to go with the LED bulb replacement.
Hey - my ‘82 has sugar scoops.
agree, if you have h4 conversion, no worries on led bulb swap.
i have an extra set of Rennline LED headlight units, if interested.
kinda thinking ill swap back to sugar scoop H4 or the sealed units with sugar scoop look.
Tmistry (02-12-2024)
Jules Dielen, at vintage trader has LED kits for the entire car, dash, brake, turn etc
(480) 686-3080
https://www.vintagetraderaz.com
Vintage Trader
Related question...if going from H5 to H4, do I need to get new trim piece or can I reuse my bodycolor trim?
Trying to avoid having to get new trim pieces painted.
