G50 3.2 common problems?
Searched but maybe I suck at searching. Apologies for repetition but is there a list anywhere where we've shared common G50 3.2 problems?
I see many about the SC but not so many about the 87-89 cars. (Maybe that's a good thing?!)
Thanks I found some good info when I searched "gear rattle G50"....especially, for rattle when idle:
You should replace the heavy rubber washer under the rear cover where the shift rod ends ... it gets pretty sloppy over the years , i installed a hard "pillow" like they call it ... it was a JW West product which i believe is Stomski now ?
Anyhow , it made a significant difference in shifter feel in my 89 G50
Cheers
Phil
Cheers
Phil
The following 2 users liked this post by wildcat077:
eggsandwich (04-24-2024),
Ironman88 (04-24-2024)
Isn't there also an updated clutch release fork and bearing kit? There is a Porsche tech bulletin that modifies the case to accept larger needle bearings. But I believe there is also an aftermarket fix that replaces the needle bearings (that dry out and fail) with bronze bushings without a case mod.
See this thread: http://forums.pelicanparts.com/porsc...ft-update.html
Mark
Mark
This info is sketchy and may be of no value - but noted in Bruce Anderson's Porsche 911 Performance Handbook - 3rd Ed. page 62:
Carrera 3.2 Checklist provided by Tony Callas:
Gearbox / Clutch
Gearbox / Clutch
- G50 reversing lever pin breakage
- G50 shifter update
- Shifter bushings
- G50 pilot bearing update
Cheers
Phil
Cheers
Phil
Shifter bushings and coupler are more maintenance items than "issues." The G50 is noisier, especially LSD - you notice it more if shifting like you are driving in the parking lot. With miles, they can be notchy when cold, but usually shifting improves as the box warms up. Release fork shaft and bushing is clutch related as much as G50. Overall, solid gear box - the rubber centered is now spring centered - adds to some noise.
Mlrjr (04-29-2024)
Here you go
It's currently out of the car as i have a Hargett shifter that i installed when i was tracking the car with PCA, all the original bits are going back in.They call it a "hard pillow " bushing, there is no part number
on it as it's some sort of hard plastic, but it will improve the sharpness of your shift mechanism.The 30 year old rubber original was pretty much destroyed when i removed it !
It's a JW West item , you'd have to check their website !
Cheers
Phil
Cheers
Phil
Not really, more LOW RPW and lugging the transmission at low RPM. It can result in jerking - but that is where you hear the spring centered clutch more than the rubber original. You do not notice it at 4K+ shifts once warmed up - but that is likely not gonna happen in a parking lot, unless you stole something.
Not a very reasuring getaway car then? Good to know.
Premium Dealer
throw out bearing arm bearings (corrected in 89 ) timing and reference mark sensors, interior supplementary blowers, DME relay, Just a few off the top of my head
Oh yes, DME relay...read lots of confusing threads there...will need to work that one out.
Is that a "if it breaks, fix it then?" Or is a good idea to proactively do that?
Here you go
Cheers
Phil
Cheers
Phil
