back dating heater
back dating heater
Friends at Rennlist, I want to back date the heater on my 1981SC. It does'nt look to complicated to do. What new or used heater pieces do I need for this project? Is there enough heat without the blower?
Thank you
Barclay
Thank you
Barclay
Technical Specialist
Lifetime Member
Lifetime Member
Apparently the article I posted on this is gone, so when I get to another computer I'll repost the article. You can see a picture of what it looks like in the 911SC FAQ on tech.rennlist.com in the last section.
Lifetime Member
Lifetime Member
Here you go. This was installed on an 81SC:
Retrofitting pre-1974 Hot Air Source
Shortly after introducing CIS fuel injection in 1974/1975, Porsche changed how hot air was sent into the passenger cabin for heat and defrostings. Starting with the first 911 in 1965, the original air system consisted of a duct on either side of the fan housing routing air through the engine tin to the heat exchangers. The new mid-70's system consisted of a fan mounted high on the left upper side of the engine bay, with 3 hoses, one for an air intake from the fan housing, and two hoses from the blower through the engine tin to each heat exchanger. Backdating the air system to the older style is easy to do, and Porsche sells the parts you'll need, or you can visit your favorite used parts dealer.
You'll need the following parts:
Left hot air duct, 930.106.321.02, list $148.20
4 plastic nuts, 999.591.592.40, list $.12 each
2 rubber plugs, 999.703.044.50, list $.77 each
Right hot air duct, 911.106.327.00, list $53.45
Right engine cover plate, 911.106.036.00, list $14.89
Right engine cover, 911.106.827.00, list $5.04
Right air duct support, 911.106.331.00, list $1.30
Hose (see below)
The left hand air duct has a bunch of holes in it to fit 911's and 930's, and the rubber plugs and plastic nuts cover those holes and allow other things to be screwed to the housing. I put a screw into each plastic nut to pretty well close off those holes. The left hot air duct is metal, and the right duct is plastic, while the right hand engine cover and plate are metal. The right air duct support is to bolt the right air duct to the larger plastic cover over the engine. I didn't use it, as things seem tight enough without it, however, we'll see if over time I need to add the support.
Installation is straight forward, take the existing blower and hoses out of the engine. On my 81SC, the bracket that holds the motor also holds one of the vacuum pipes, so I took the whole bracket off, and cut off the portion which held the motor, leaving the portion that holds a support for the pipe. Put the left hot air duct in. On the right, unscrew the cover plate and remove it. Put in the engine cover plate, followed by the right air duct, followed by the engine cover. The right air duct has some grooves in it where the engine cover cinches it up fairly tight.
Hoses: I used 4 feet of 2 1/2" SCAT hose (silcone rubber-based, good to 450 degrees) from Aircraft Spruce and Specialty. You'll cut two pieces for the left side (duct to engine tin, then below engine tin to heat exchanger) and one longer piece on the right (duct to heat exchanger). I've also seen an aluminum-based hose used, as well as other types and colors. The hose has to stand the heat in the engine compartment and more importantly the heat at the heat exchanger connection.
That completes the installation. Assuming your heater boxes are working, and the wires to the heater controls on the floor are also intact, you're done! Not much heat at idle, it picks up well as the revs increase. If you open a window just a crack, then that helps the heated air move into the compartment. And you can now see, and access, more of the engine!
Hose (see below)
Yes it is Rosewood Metallic.
I wouldnt expect it to affect your smog test. Who knows though with the new regs in Kalifornia.; )
The heat is plenty for me. You need to realize that the fan is now your blower and rpms= more heat. Just another excuse to let er rip.
Tim
Tim
