BBS LM wheels
BBS LM wheels
I'm thinking of getting a set of 17's to replace my 16" Fuchs on the '87.
What widths/offsets should I get?
im looking at my reciept and it says BBS 7.5x17" LM 2-piece forged wheel (25mm)
BBS 9x17" LM 2-piece forged wheel (17mm)
also item numbers BBSLM135, and BBSLM136
dont know it thats any help at all.
Jerry - Did you need to roll the front fender for clearance? Is your car lowered?
What size tires do you use? Thanks!
215/45 and 255/40
fender lips are rolled but if at stock US height I think it might be fine. I've been messing around with the front end alot, drove around a little with it very low, no problems, right now it's back to stock height. I'm waiting to do up the rear end before I take it for alignment and balance
The widest you can do is 8's and 10's, pretty much, with 245/275 tires. For that, you need to move an oil line slightly, machine down the head of a swing plate bolt, and roll the inner lip of your fenders. It's not a huge amount of work, but all 911's are a little different, so YMMV.
What do the BBS wheels cost? I have 17-inch 2-piece wheels made with Fuchs centers, which might be an option for you to look into.
Thanks for the replies. JackOlsen: they're not cheap. Around $3500 for wheels and tires. I think they're the best looking aftermarket wheel for late '80s Carreras.
Well, you're right. That's not cheap. But wheels are expensive.
When I had an RS/SC/Carrera-flared car, I ran 8x10x17 wheels on it from Lindsey. If you like Fuchs, it's a cool way to update to wider tires and larger-diameter wheels without looking like an old 911 that slapped on a new model's wheels.
At $2100 a set, they're cheaper than most good aftermarket wheels, and they're aksi lighter than real Fuchs in the same width.
Legacy Flounder
Speaking of wheels in that price range, does anyone have photos of a 911 with 17" Fikse FM-5's mounted? One of my favorite wheel styles, but I can't picture how it would look on the curvatious 911 profile.
FWIW, ask Don Kane at Team Dynamics (US) about any fitments you might have. I picked up some 15lb 17x7 wheels from him for my SHO, under $600 shipped for all 4. Certainly not forged alloys, but they survived very nicely during everyday pothole-infested New England roads, as well as 2 days at Road Atlanta on a 3600lb car/driver combo including an at-speed offroad excursion when a driver spun right in front of me.
I know TD offered some forged wheels too at some point, including some with the Porsche in mind.
I have LM's for street wheels on my 89 and like the look. They are 7 1/2 and 9" wide. I am pretty sure they are designed for the early to mid cars and only come in 1 offset. Got them from wheel enhancement a few years ago. I Would not use them for track though, as they are a lot heavier than my 16" fuchs track wheels, and I can definately feel the acceleration difference.
Legacy Flounder
Peter may have 16x6 / 16x7 ?
Thanks very much for the FM-5 photos, MUCH appreciated (interesting, but I don't think quite the look I was going for).
My track tire/wheel combo is 16 x 7 and 16 x 8. Tires are MPSC or Hoosier.There is a very significant difference in weight between those and the LM's with SO3's on them. I have not bothered to weigh them, but the difference is very noticable when changing wheels and when accelerating.
