classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | My Recent Topics | Vendor Directory |
Thread Tools |
#16 |
User
personally, i would spring for it- and im not rich, trust me. this is a car that's gonna last a long time and give you endless pleasure so it seems the right move to get the right one (tests out well!) so that youy don't get bitter over it later- things will happen periodically even if it does test strong, that's the nature of the beast- just a good idea to get a fit beast from the start so as to get a bit of reliability in your maintenance over the years and get bills in the hundreds or DIY parts bills rather than some huge bills for major issues you missed by saving a few bucks on the full health check- it will give you big time peace of mind! good luck and enjoy that beast!
#17 |
Rennlist Member Join Date: Oct 2004
Whoa, whoa, whoa!!!! Let's start with your PPI - have somebody that knows what they're doing do the next one! Of course you need a leakdown test - the car is almost 20 years old! The tire issue is easy - just read the date code on the sidewall, if they're older than 5 or 6 years, replace them. What on earth is item # 5? You can't "tighten" Carrera timing chain tensioners! He doesn't want to do a leakdown unless "the valves are loud," but then I read your # 7...huh? $250 to fix the A/C, huh? I don't think so! $1500 is more typical, and it could go higher than that. A engine and G-50 transmission being "rebuilt" at 90K miles? What the heck for? Your "$500" won't come close to paying for this car's problems. Man, don't walk away from this car - RUN AWAY!!!
Pete |
#18 |
Best of luck to you.
Pete |
#19 |
User
Just had PPI done yesterday for 88 slant turbo with 69 K miles......compression test showed 145 consistently, valves good, upgraded turbo K27 and upgraded intercooler fine, needs alignment and clutch lowered and adjusted, and fluids to be changed. No sign of rust, corrosion, brakes 1/3 gone and a/c system warm but expected. The only concern is upgraded exhaust pops alot..sounds good but is the popping normal for this car?
#20 |
A different exhaust is, many times, not an "upgrade." And yes, aftermarket exhaust systems can often make unusual noises; your PPI tech should have explained that to you, perhaps pointing out a stress crack, a blown gasket, etc. More things than the exhaust can cause popping, unfortunately, with Turbos, they're not all the same, and virtually impossible to diagnose in a forum like this. A second opinion might serve you well...
Pete |
#21 |
I would like to take this opportunity to thank all of the readers who have shown an interest in this post, and sincerely hope that it's been helpful. Happy Thanksgiving 2006 to all!
Pete |
#22 |
User
Hey Pete, happy thanksgiving too..................... I'm looking forward to getting my own car back on the road, and on a road trip up north with it, I will stop by and say hello.
Murphyslaw, ever buy that carrera? As the old saying goes, Fools step in where angels fear to tread....... |
#23 |
Rennlist Member Join Date: Oct 2006
Hey Peter,
Your contributions to this forum are priceless! I just ordered your book on Amazon...Looking forward to some great winter reading! Jeff |
#24 | |
Rennlist Member Join Date: Aug 2006
Quote:
#25 |
User
Glad to hear everything worked out. Having an engineering back ground, you can really appreciate the thought processes and development of these cars more than most I'm sure from another prospective
#26 |
Rennlist Emeritus
Lifetime Rennlist Member Join Date: Jun 2000
Link to this thread added to the Admin post at the top.
Unsticking this one.
Randy V. San Diego, California '94 928 GTS - Midnight Blue Metal
#27 | |
Rennlist Member Join Date: Mar 2009
Quote:
#28 |
1stgear: You should probably start a new thread titled, "Help, Charging System Problem" or similar - you're likely to get far more activity. Be sure to list year, model, and any changes/mods such as a different engine (3.2L in an SC, etc.)...
"Freedom of speech means that you shall not do something to people either for the views they have, or the views they express, or the words they speak or write." - Hugo L. Black, U.S. Supreme Court Justice 1963 "QUIT MAKIN' THINGS UP!" - SARAH P. ![]() Keep the shiny side up! Pete Z. ![]() |
#29 |
New User
I was reviewing forums.roadfly.com/porsche 911. Re: Victory Motor cars-Beware. Apparently Robert Neal at Victory Motorcars (independent dealer) has been deceiving clients with severely compromised porsches, misrepresenting their problems. Some have made claims that he recommends mechanics shops for PPI, that he pays off to conceal their problems. There is great corruption going on there
| Tags |
| 911, bearing, check, clay, connecticut, excessive, grady, inspection, list, mechanic, play, porsche, pre, prepurchase, purchase, vw |
| Thread Tools | |
