lights "surging"
As some have mentioned, the most likely problem is an intermittent voltage regulator
causing excessive battery voltage, i.e. >15 volts. This is a common problem for 3.2s
with the internal Paris-Rhone alternators.
I cleaned the grounds and it hasn't changed. I haven't driven the car since, and it's going into winter storage soon, so I'll replace the voltage reg over the winter.
Originally Posted by joey c
i just went through something like this but it was dimming.the seatbelt light went on.low voltage and a new alternator was the fix.everything is fine so far....
