911 Forum 1964-1989
Alternator fan belt nut froze
Old 04-18-2006, 02:40 PM
redidrum
redidrum's Avatar
Ice,
Yes, I have a motorcycle c spanner that just needs ground out a little wider and a smaller hook hole. Should I install new shims? Thanks, Ron
redidrum is offline
Old 04-18-2006, 03:33 PM
Peter Zimmermann
Peter Zimmermann's Avatar
Ron: I don't know if using an allen wrench in the end of the shaft might possibly load/harm the alt. bearings, etc. The factory instruction is to use the spanner, so that's the only method that I've ever used.
Pete
Peter Zimmermann is offline
Old 04-18-2006, 03:43 PM
redidrum
redidrum's Avatar
Okay, I'll bite the bullet and get a spanner. May be able to mod. the one I have. Thanks so much to everyone. I was concerned that I could damage the bearings. Best Regards, Ron
redidrum is offline
Old 04-18-2006, 05:51 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,048 Likes on 746 Posts
go for it... i do it the way Pete suggests as basicall I am a chicken and don't want to slip and eat the housing... but the fact you are asking about new shims s positive .. you are already conviced it is coming off... I got new shims because i didn't put them back right and crushed the old ones ( they slipped down as I was putting the pulley on ... but no you don't need replacements, you play with the ones you need with every new belt anyway ..
theiceman is offline
Old 04-18-2006, 06:03 PM
cmoss
Guest
Posts: n/a
good boy--and don't forget the six pack for when the job is done.
Old 04-18-2006, 06:06 PM
redidrum
redidrum's Avatar
Just gave our friends at Pelican $87 for the spanner wrench and some other goodies I needed. It's all good. Patience!!! Thanks Guys! Ron
redidrum is offline
Old 04-18-2006, 06:10 PM
theiceman
Team Owner
theiceman's Avatar
I you use a tool once and it works .. then it is worth it...
Old 04-18-2006, 06:44 PM
Peter Zimmermann
A couple of small dabs of grease on those shims goes a long way toward keeping them in position!
Pete
Old 04-18-2006, 10:04 PM
theiceman
Team Owner
theiceman's Avatar
doh ...... !
Old 04-19-2006, 10:23 AM
Chris Holcombe
Chris Holcombe's Avatar
Moot point now but for what it's worth the allen wrench hole is common on most automotive alternators and it's purpose is to hold the rotor shaft so you can take the nut off. The trouble is if the nut is on really tight you are going to twist the end of that allen wrench off. Look at the size of the wrench on the nut and look at the allen wrench, it's no contest in who's going to win the torque battle.
Chris Holcombe is offline
Old 04-19-2006, 10:26 AM
theiceman
Team Owner
theiceman's Avatar
I'll be interested to see how Ron makes out ..
Old 04-19-2006, 10:44 AM
redidrum
redidrum's Avatar
Just for grins last night after sprayiing the damn nut 3 times with penetrant I thought I'd try the allen wrench and open end one last time. I'm a pretty strong 225 lb boy. Bought a new 24mm socket to use with spanner and an open end 24mm to give one last shot at the allen wrench. No go with an extension pipe on both ends without feeling like I'd break something. Waiting on spanner wrench again. Went ahead and bought all new Rolex nut, Cartier washers, and Bulova shims from Pelican Luxury Jewelry House.
redidrum is offline
Old 04-19-2006, 11:49 AM
theiceman
Team Owner
theiceman's Avatar
Did we forget to tell you it is a left handed thread ??? ......................... oh relax I'm just kidding .. it's right handed...
I know what you mean about pelican parts, They do have a great site and forum and tech articles , but boy are they pricey..
something tell me when you crack that nut it will be hot .... PS drape some old towels over those fenders and back area, you would hate to slip and ding something ....
Old 04-19-2006, 04:45 PM
911 Rod
911 Rod's Avatar
The spanner wrench came with my tool kit.
If it should be there, are there no other Porsche buddies with complete too kits to help?
911 Rod is offline
Old 04-19-2006, 08:26 PM
r911
Anti-Cupholder League
r911's Avatar
"boy are they pricey..."
Pelican raised their shipping (on small & medium orders), but I don't find their parts prices all that pricey - generally on the low side tho not the cheapest.
Are there certain parts you're thinking about? Or certain other vendors?
r911 is offline
Quick Reply: Alternator fan belt nut froze
