Adjusting the hood... tips?
Legacy Flounder
Well, after replacing the hood struts a couple of months ago, I noticed that now the hood is actually "up" a little on the driver's front corner (see photo).
Is this a latch adjustment, too-powerful struts (Pelican's), or something else? I tried replacing just the pass. side, doesn't hold the hood up with the old one on the driver's.
Any advice on adjusting this appreciated, it's gotten to the point of really bugging me.
Legacy Flounder
With the old saggy struts it was flush. With the pass side only replaced, it was flush (but wouldn't stay up). With both installed, I get what you see in the pic.
Ah, ha! That's why the car won't shift right!
Actually, Fred, it looks like someone re-adjusted the lower latch to accomodate a bra - that's about the right amount of clearance required. You can fix that by lifting the black piece of plastic away from the lower latch - or there might be two pop-out plugs like the ones used on your doors for the window frame bolts. The bolt heads face backward toward the dash. You'll find two bolts, probably allen head type. Loosen those and gently tap down on the latch, when it has moved a little re-tighten the bolts and check the adjustment. If my fix doesn't work, and you end up never being able to open your trunk lid again, please accept my apology in advance. I'm leaving now...
Pete
Pete
Legacy Flounder
BWAHAHAHAHAHAHAHAHAHAHAHAHAHA!
Thanks Pete, I needed that one.
I do think you're right-on, the PO had a bra for the car. If your latch is captured or killed, Pete will disavow any knowledge of your actions. Thanks for the tip Pete.
Edit:
So, segue into... terminology. I called it "hood". What's the standard way to discuss the storage compartment vs the engine compartment on these cars, with the engine being in the "correct" location vs. traditional location?
trunk, boot, engine bay, hood, engine lid, where da fuses live, where da whaletail at...
I'm off to have a beer & adjust away, then maybe swing by the cruise night at the diner with the family. Thanks all!
Edit:
Legacy Flounder
Aw dayum Pete, now I can't get the lid open!
J/K, I move the latch down, and went slightly up on the bumper to help level out the hood - seemed like it was tweaked just a little. The bumpstop on the driver's side was already bottomed, too.
Much better, and as always, thanks for the help folks!
Good news! Don't worry about the hood (aka "trunk lid"), after you look at about 100 cars like yours, and 99 of the lids look slightly tweaked, you'll realize that it's normal. Now that you've changed an adjustment put the car through a few slow corners, quickly, and make sure the lid stays shut. Glad to help!
Pete
Pete
1 Post
Bentley Carrera '84-'89 book has specs for drilling a hole to enable opening the lid if unable to open with factory cable on p 550-4. The bad news is you have to remove bumper. I don't know about other Bentley's. That latch jamming closed can make you nuts. It's alignment with the male pin is important. At least with the engine lid latch you can drop the muffler and drill a hole for access if routine disconnecting cable handle and ++ fails.
Pre '74 is easy to run a hidden cable opener. '74+ is different afaik.
I can't post a pic for some reason and I never get a reply from rennlist for why my HTML is not activated in case that's the reason.
if anyone needs an emergency fax send me your info. or maybe someone with the Bentley can post a pic.
