911 Forum 1964-1989
911 SC Simple Performance Modifications?
Old 12-06-2006, 07:34 AM
964_UK
964_UK's Avatar
Default 911 SC Simple Performance Modifications?
Hi guys,
I have added an induction kit, a Sports Pre-Silencer and I am looking to purchase a custom made performance rear silencer.
What other simple modifications can be done to increase performance?
I have an 83 SC so chipping is out.
Cheers
Craig
Old 12-06-2006, 09:17 AM
DB_NC_95C2
DB_NC_95C2's Avatar
SSI exhaust headers into a 2-in-1-out performance muffler (assuming you don't have emissions sniff tests as part of your inspection laws). That was my biggest improvement.
Old 12-06-2006, 12:06 PM
964_UK
964_UK's Avatar
I think I am going to compliment my Sports Pre-Silencer pipe by adding a Muffler Bypass Pipe.
Luckily I know a guy who can make these pretty easily so saves me £200 getting a new performance rear box, it also seems to be a very good performance mod, not to mention the sound!
What you guys think?
Old 12-06-2006, 03:58 PM
dave1200
dave1200's Avatar
I just did this with a dual in dual out set up... without tearing into the engine to change out cam and stuff... SSI's and exhaust are almost your only options other than suspension and tires and brakes.
you wont see a huge jump in HP or anything, but the car does act better and is louder.
Old 12-06-2006, 06:33 PM
2002M3Drew
2002M3Drew's Avatar
1. SSIs and 2/1 exhaust (as suggested...BEST bang for your bucks...amazing!)
2. 930 Tie Rods
3. New suspension bushings (preferably ERPs)
4. Lower the car (Free, just time)
5. Remove stuff and lighten the car (free)
Old 12-06-2006, 06:37 PM
JV911
JV911's Avatar
1. Exhaust
2. Turbo tie rods, urathane suspension bushings & suspension set up
3. Brake pads & fluid
Old 12-07-2006, 05:06 PM
Clipboard
Clipboard's Avatar
Rip out every bit of the a/c usystem and throw it as far away as possible.
john
Old 12-07-2006, 05:12 PM
DB_NC_95C2
DB_NC_95C2's Avatar
john
if he lives in the UK, maybe so, but in my climate I'm going to all RennAir stuff in the spring. Have it in a box but don't need to mess with it right now.
Old 12-07-2006, 08:27 PM
r911
Anti-Cupholder League
r911's Avatar
the items you bought will not increase the performance.
if you can put SSIs on (no emissions check) that will help
Old 12-07-2006, 09:46 PM
Bill Gregory
Technical Specialist
Lifetime Member
Bill Gregory's Avatar
If you haven't already, you may want to read the 911SC FAQ at tech.rennlist.com
Old 12-08-2006, 07:50 PM
964_UK
964_UK's Avatar
SSI Heat Exchangers look sweet!
Old 12-08-2006, 09:08 PM
Edward
Addicted Specialist
Edward's Avatar
Hi Craig,
As been stated, the SSIs are a wonderful mod that really does offer real-world-driving improvement, but it's only worth it if you don't have to comply with smog regs. The other thing I would recommend is ditching as much weight as possible. You can certainly start with the a/c and all its plumbing, then move into the interior by eliminating rear seats and replacing the heavy fronts. Engine pad, too. 150 lbs is totally do-able and makes a great difference in the handling!
Suspension is fairly easy and offers great bang-for buck, as well. Lots of opinions/options here; a search might give you some ideas. But dropping a bit of weight along with even mild chassis upgrades can really transform the feel of your car.
Edward
Old 12-12-2006, 11:10 AM
Sammyg2
8th Gear
Sammyg2's Avatar
Induction kit? Waz that?
Old 12-12-2006, 12:41 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,588 Likes on 992 Posts
Originally Posted by 964_UK
Hi guys,
Cheers
Craig
I would work on lightening the car. Usually this is cheaper than buying expensive add-ons that don't always improve performance. Lightening the car always works!
Old 12-12-2006, 01:38 PM
dmw44
dmw44's Avatar
What I've done:
File Type: doc
Quick Reply: 911 SC Simple Performance Modifications?
