Have clutch questions..Need help
Was racing around last night and started getting the burning smell from the clutch on an '86 Carrera. Clutch is supposed to be new (car is new to me) Today I was getting the same smell.
Questions:
Can the clutch be inspected for wear on a rack w/o pulling tranny?
How hard or how much shop time is an adjustment?
If I need replace it (I hope it just needs adjusting) is there a more durable upgrade?
Questions:
Any competent Porsche shop can your clutch. 1/2 hour should do it on your 86.
Bill
www.rudtnersracing.com
Bill
I guess my question is can a clutch be inspected or atleast an assessment of it's status without tearing it down like for instance inspecting brake pads
Nope, the clutch is sandwiched in between the engine and the transmission, so to inspect it you need to drop the engine and tranny. Big bucks. I would let an experienced mechanic drive the car for you. I don't know, but maybe that smell is supposed to be there if it is a new clutch. If it only smells funny and does not malfunction, it shouldn't need replacement. Are you worried that it isn't actually new?
To adjust the clutch, look at Wayne Dempsey's 101 projects book. I've never done it, but I removed my engine and tranny so I have an idea of what it would take to do it. Not much. Even if you don't do it yourself, reading the chapter will give you the necessary background to communicate with your mechanic.
My '69 911 has a brand new clutch (and tranny, and engine...), and it does give off some slight smell sometimes. I think it is just part of getting broken in. I am pretty sure you want to limit your rpms when there is a new clutch too, until it is broken in, but I could be talking out of my ***. I'm no mechanic.
It wasn't smelling at first at all (when I recently bought the car) raced around the other night (pretty hard) and it started the "smell". I'm worried I tore up the clutch, It seems to be shifting fine just the "smell".
Don't be hasty to say the clutch is bad. It will give off some smell for a short time. Take iot too a local reputable shop and have them check and adjust it. Sounds like it is way out of adjustment. If you wait too long, you may wear it out and really have to replace it.
You only have to slip it once for a few seconds to get that nasty smell and it does linger. So you have to think back when you were pushing it, if you slipped the clutch at all. Not really a big deal, just not something you want to do too often or as Daniel Dudley mentioned, the heat will cause the flywheel surface to glaze over time. Don't panic.
