911 Forum 1964-1989
Fan Blower
Old 02-07-2008, 12:45 PM
lfe132
lfe132's Avatar
Question Fan Blower
I have a 84 Carrera and I was checking out my fan/blower in the front of the car. The blower housing is cracked and broken and I will eventually replace it. But my question is; how exactly does this fit. It looks like if it is mounted the battery will not fit. Or maybe the PO put in the wrong blow, trying to make it work. Check out the photos and let me know if you guys have any idea on the subject.
Thanks.
Old 02-07-2008, 01:10 PM
KC911
KC911's Avatar
Want to drop 25 lbs or so, ditch that HUGE boat anchor of a battery ! I remember when I replaced my battery (it had a Porsche label, and I think it was a huge interstate similar to yours) with a red top Optima and I was delighted at how small it was by comparison, not to mention the weight. Your's is crammed in there, and I can see why you might have a clearance issue with the condensor fan. I've also removed my fan (when I ditched the a/c), but you need to fuse that sucker before you attempt to use it to be safe. They are notorious for burning up 911s, so search the archives for that issue. Good luck and hope this helps...
Keith
'88 CE coupe
Old 02-07-2008, 01:54 PM
Stevie 77 930
Stevie 77 930's Avatar
+1 Right blower, wrong battery.
Old 02-07-2008, 02:16 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,026 Likes on 730 Posts
Although your car is speced to fit this battery and has the correct tie down for it you do have options even if you do not want to splurge for the optima. Take your battery out and you will see another tie down bolt hole further back to fit a smaller interstate. I can't remember the group number but I am sure someone will chime in with it in a few minutes.
Good luck
Old 02-07-2008, 02:35 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,580 Likes on 987 Posts
Those fan housings will crack and break apart over time, so it's not unusual to hear that the housing and/or motor might need to be replaced.
My car had a huge battery in it as well, but I like having all that battery power. That said, if I needed a new battery, I'd choose Oddysey or Optima instead.
Old 02-11-2008, 05:35 PM
der Mond
der Mond's Avatar
Default Optima
This is what it looks like, using an AJ adapter plate.
Old 02-11-2008, 05:38 PM
der Mond
der Mond's Avatar
Forgot to mention that it needed a new, slightly longer ground cable, which I got from NAPA. The end attached to the car was hard to get off because the windshield washer feed tube was stretched tight over it, but I did it at -10 F. at night with a headlamp!
Old 02-11-2008, 07:26 PM
Mike Murphy
By the way, I went to the Chicago Motorcycle Show this past Sunday. There was a dealer there who sells both Optima & Odyssey & Powermaster batteries. Not sure if these are good prices, but I have a price sheet that describes the following:
OPTIMA 500CCA $158.95
OPTIMA 650CCA $176.95
OPTIMA 750CCA $191.95
OPTIMA 900CCA $232.95
ODYSSEY 535CCA $112.50
ODYSSEY 680CCA $121.20
ODYSSEY 925CCA $165.45
ODYSSEY 1200CCA $178.40
ODYSSEY 1500CCA $225.95
ODYSSEY 2150CCA $330.70
Let me know if anyone wants the price sheet (based out of Illinois)
Old 02-13-2008, 03:01 AM
ajmarton
ajmarton's Avatar
COSTCO has the best prices for OPTIMA batteries.
Old 02-13-2008, 11:51 AM
Mike Murphy
Do you have a link? I went online and couldn't find any.
Old 02-13-2008, 11:55 AM
Edgy01
Poseur
Edgy01's Avatar
Definitely the big battery is coming int ocontact with that housing. The correct battery doesn't do that.
Old 02-14-2008, 11:05 AM
ajmarton
ajmarton's Avatar
I guess it's not on their web page - perhaps because of shipping issues but they have it in store. Hopefully there is one near you or I would call the 800 number and see if you can order it.
Old 02-14-2008, 12:18 PM
Mike Murphy
Costco rocks, but I have a household of 2 people right now and an 852 square foot apartment, so it's a little bit silly right now. Have to get a bigger house and make some babies.
Old 02-14-2008, 01:02 PM
Amber Gramps
Amber Gramps's Avatar
Murphy, when is the big day?
Isn't the Optima just a private label Interstate? Interstate is a customer of mine and I keep seeing them on display in the lobby at all the So Cal Distribution centers. May be wrong, but I'm perty sure.
Old 02-15-2008, 01:20 AM
Droops83
Droops83's Avatar
That is indeed the correct size battery as originally equipped in the 3.2 Carreras. It is a very tight fit in there, and if you are not careful you can damage the condenser blower motor. Many customers insist on keeping the same size battery as stock so I have put tons of these in and it can be a bit of a pain. Since you are in SoCal and I doubt will be cranking the engine in subzero weather, you can downsize to the MTP-91 from Interstate which is the same size as the OE battery in SC and older 911s and will fit right in with the same factory hold-down bracket you should have now; otherwise you can do an Optima or something like that.
However, Optima batteries are not what they once were, and not worth the money IMHO. Ever since Johnson Controls took over em they don't last nearly as long as the old ones did. That same company owns Interstate too, but they still seem pretty good, we sell Interstate and they generally last 5 years or so like any other maintenance-free battery does and have a good warranty. Also it is tempting to buy cheap batteries at Costco, but if you check the date codes, they are often a year old or more, and won't last as long.
Quick Reply: Fan Blower
