Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
marketplace | store
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 911 Forum
New! Use your Facebook to securely log into this site, click logo to login
Old 02-09-2008, 02:09 AM   #1
mnmasotto
mnmasotto's Avatar
Send a message via AIM to mnmasotto
Default 911 Max chip in my 1987 3.2 Carrera
I recently installed a 911 Max chip by Russell Berry. I have had the chip in my car for the past few days. Wow, what a difference a chip can make! The power curve and throttle response could not be better. I previously had a SW chip which I absolutely loved. I think the 911Max chip may offer a little better throttle response. If you are currently using the stock chip, take it out and save it for your smog test. I have done many mods to my car, however, this is by far the best so far.
1987 Carrera with MoTec 3.6L motor
2006 BMW M3 Competition Package
2007 997.1 GT3
mnmasotto is offline   Reply With Quote
Old 02-09-2008, 10:17 AM   #2
justinsrx7
justinsrx7's Avatar
Quote:
I bought my car in October and have only put a couple of hundred miles on it before i had to put it away for the winter. The person I bought it off suspected it had a chip, but I have no idea if and which one. What I do know is when the engine gets hot, the engine starts revving as if the computer program is hunting. Some suggested I might replace a valve (can't remember the name but EVO valve or something). Others suggested it might be the chip. What are the specs on your new chip, I.e., hp and torque increase? Have you experienced teh revving engine before? How much was the chip and did you install it yourself?
Thanks for the info.
'78/'86 Turbo-look Cab
'93 3rd gen Mazda RX-7 - Sold - oh what a mistake that was :-(
'00 Audi A4 Quattro
justinsrx7 is offline   Reply With Quote
Old 02-09-2008, 12:26 PM   #3
amber lamps
OT Attention Whore
amber lamps's Avatar
Justin, I have the same chip as mnmasotto. The throtle response is instant and strong. It wasn't gained by advancing the timing to some crazy 30 degree number as some have thought but buy changing the fuel map. To give you an Idea of how strong the engine is now I am currently adding drilled zimmerman brakes and am only a week or two away from a full Bilstein HD / poly-bronze sport suspention build with the help of Steve Weiner. I had been driving the same roads for a year with my car acting like a slow lumbering slug when I did a cat bypass and the MaxHPkit chip. Now the car keeps getting away from me....I could let off the gas, but that's not like me. I can honestly say it's not the same car!
the quickest way to tell if you have a chip is to remove the driver's seat or move it all the way up and back, remove the four nuts on the DME computer and the one on the cable, flip it over and see if you have scratch marks around the tabs. If you do have scratch marks you may have a chip. to make sure disconnect battery. once you pry open the DME, the stock chip has a bunch of numbers on it. Mine said 1267355358. the custom chips usually have the makers name on them. I think the MaxHPkit is $300 or $350. well worth it.
EDIT: Justin, I just saw your signature...is you engine a '78 or is it an '86?
if you have no 3.2 you have no chip? She is perty though.
amber lamps is offline   Reply With Quote
Old 02-09-2008, 03:44 PM   #4
911vet
911vet's Avatar
Quote:
Rub it in, Doug. I'm so jealous.
Shannon
Don't Blink Racing (Against Time)
87 911 Cabriolet
96 Miata track car
911vet is offline   Reply With Quote
Old 02-09-2008, 03:59 PM   #5
old man neri
User
old man neri's Avatar
Quote:
So what's the word on your clutch/trans problem you went to go see the 'doc' about?
old man neri is offline   Reply With Quote
Old 02-09-2008, 04:35 PM   #6
911vet
911vet's Avatar
Quote:
I'm getting a second opinion. The first doc failed to diagnose it. So it's off to a new mechanic on monday.
I'm leaning towards the idea it may be loose shift linkage in the tranny (or somewhere rearward of the coupler that's under the rear access panel).
It's still a mystery. I'm still hoping it's NOT the tranny itself. But whether it's clutch, tranny, or shift linkage... it's gonna require an engine drop I think.
And once I get this resolved.... I'm installing Bilsteins, a front sway bar, and all the other stuff so I can challenge Doug to a race.
Shannon
87 911 Cabriolet
96 Miata track car
Old 02-09-2008, 05:10 PM   #7
amber lamps
OT Attention Whore
Shannon we are way off topic here but I want to point something out. I would love to not be doing the zimmermans and I'm sure as soon as I'm done with the suspension I'll wrap it around a tree....
Old 02-09-2008, 07:38 PM   #8
justinsrx7
justinsrx7's Avatar
EDIT: Justin, I just saw your signature...is you engine a '78 or is it an '86? if you have no 3.2 you have no chip? She is perty though.
Hey Douglas. It is a '78 body with an '86 3.2 engine, so I am chip eligible :-)
Thanks for the info. Do you have to do a cat bypass, and does that change things when ordering the chip?
'00 Audi A4 Quattro
Old 02-10-2008, 02:51 PM   #9
oceanvue
oceanvue's Avatar
That's your ICV or Idle Control Valve someone was probably talking about if it's a 3.2. They get carbon in them and can cause surging. You can pull them off and squirt brake or carburator cleaner in them and you might be shocked at the gunk that comes out of them. If that's not the problem you probably need the air flow meter adjusted.
oceanvue is offline   Reply With Quote
Old 02-10-2008, 03:20 PM   #10
justinsrx7
justinsrx7's Avatar
Quote:
Yes, it was the ICV they told me about. Thanks for reminding me. Someone else also told me that it could be the chip I currently have in the computer hunting. Although it seems to happen only when the car is sitting in traffic and gets hot.
'00 Audi A4 Quattro
Old 02-10-2008, 08:48 PM   #11
rberry951
Temprarily Banned per IB
rberry951's Avatar
Send a message via AIM to rberry951 Send a message via Skype™ to rberry951
Quote:
Hey justinrx7,
I could be the chip causing the hunting, some after market chips map out the closed loop O2 sensor operation. At idle, and any time the car is running in the part throttle maps and not under acceleration the computer enters closed loop mode where it reads the O2 sensor and maintains stoich AFR of 14.2-14.7:1. So it could be a chip that mapped out this function, and didn't properly change the cold start fuel correction tables, or it could just be that your O2 sensor is bad. What Douglas said above about checking for stock or aftermarket chip is correct. My chips use the O2 sensor the way it was meant to be used. I know in other cars the Autothority chips, and variants thereof, which make up most of the 944 aftermarket chips, map this out. They also tend to run very rich in mid ranges. Ever see any black smoke coming out of your exhaust under full throttle?
If you do decide to purchase our chip products and the idle continues to hunt, I'll be happy to help you take the necessary steps to rectify the problem if the chip does not.
Regards,
Russell
rberry951 is offline   Reply With Quote
Old 02-10-2008, 09:34 PM   #12
justinsrx7
justinsrx7's Avatar
Quote:
Originally Posted by rberry951 View Post
Hey justinrx7,
Regards,
Russell
Thanks Russell. When the weather gets a bit warmer, I will take our my computer and see what is currently in there and let you know.
'00 Audi A4 Quattro
Old 02-14-2008, 01:23 PM   #13
m491driver
User
m491driver's Avatar
Any new observations regarding this chip? As a previous Steve Wong chip buyer, I'm interested in hearing more experiences.
m491driver is offline   Reply With Quote
Old 02-14-2008, 03:37 PM   #14
SpartanToJo
User
SpartanToJo's Avatar
Quote:
I would LOVE to give some feedback about Russell's chip that he so generously sent me for evaluation. However, it has been close to ZERO here for some time and we have a foot of snow on the ground (which means an inch of salt on the roads...)
Oh sweet springtime, please come soon!!!
SpartanToJo is offline   Reply With Quote
Old 02-14-2008, 03:37 PM   #15
2002M3Drew
2002M3Drew's Avatar
Just out of curiousity...since the Steve Wong chips are so well known, tested, and proven, why would someone would go with an unknown quantity here?
1992 Porsche Carrera C2: Amazon Green/black (Track)
1983 Porsche 911SC Coupe: Ruby Red Metallic/Black (Autocross)
2006 Porsche Cayenne S: Carmen Red/Black (Support vehicle)
2002 BMW M3 Coupe
2004 Saab 9-3
1992 Mazda Miata
2000 Buell Cyclone M2
PCA National Drivers Education Instructor
2002M3Drew is offline   Reply With Quote
Tags
1987, 32, 87, 911, 911max, carrera, chip, chips, engine, flow, maxhp, meter, problems, steve, stock, wong
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Contact Us - Rennlist Discussion Forums -
Privacy Statement - Top
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
