what could this be
it sounded like it was gonna start,but nothing..i also noticed the other that it felt like it wanted to stall,after an hour drive...i should not that i got caught in the rain the other day...and i had a few drops of water hitting my feet...maybe through the windshield..
Team Owner
I'm going for the accumulator too
the fuel pressure didn't hold and you have no cold start enrichment to help you out. I would pull off the vent side hose of the accumulator, if fuel comes out the diaphram is shot .
+1 on having a "good", spare DME relay (which also houses the fuel pump relay). That may not be your issue (in this case), but it eventually will be. No 3.2 owner should be without a spare unless you like being stranded .
Keith
'88 CE coupe
Keith
'88 CE coupe
Best....
Doyle
