911 Forum 1964-1989
HELP! CA smog testing on 911 with B&B Tri Flow
Old 12-05-2008, 07:01 PM
Marty916
Marty916's Avatar
Yes, the test station near CT Automotove is a test only place. They treated me very well and know their stuff. Here's their info: Accurate Smog Ctr
210 Curtner Ave # 4, Campbell, CA 95008
Old 12-06-2008, 04:53 PM
dvkk
dvkk's Avatar
Originally Posted by Sherry
...., and adjusted the oxygen sensors....
I bet they changed the muffler bearings too.
O2 sensors are not adjustable. It is either good or bad. Replacement is the only option if it is bad.
Fuel additives do nothing to help smog numbers.
It seems to me they don't know what they are doing. I suggest finding another shop.
Post ALL the numbers from your test report. The cause of high NOx is different from the cause of hich HC. Nobody here can help you if you don't give us the numbers.
Quick Reply: HELP! CA smog testing on 911 with B&B Tri Flow
