Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 911 Forum
Old 08-18-2009, 01:03 PM   #1
dan proudfoot
Default FIRE IN SC ENGINE COMPARTMENT
Driving in 90 degree heat last Friday, with engine temp 215 degrees, the plastic hose connected to the heater blower and the sound inhibiting pad on the firewall ahead of the engine somehow conspired to catch fire.
That is, chunks of the pad fell down and turned to flame at the bottom front of the engine - that was the view I was confronted with when I opened the lid. And the blower plastic hose had split and partially melted from the heat. I am not sure of the order of these two events. Maybe the hose melted first, then hot air was directed on the sound deadening pad, and then the pad fell apart/ignited.
Good thing I had a fire extinguisher with me.
Anyone have a similar experience?
Dan Proudfoot, Toronto
dan proudfoot is offline   Reply With Quote
Old 08-18-2009, 03:34 PM   #2
douglas bray
douglas bray's Avatar
Welcome to rennlist Dan. You'll figure it out....
douglas bray is offline   Reply With Quote
Old 08-18-2009, 08:27 PM   #3
Daniel Dudley
No gas leak ?
Daniel Dudley is offline   Reply With Quote
Old 08-18-2009, 08:29 PM   #4
theiceman
theiceman's Avatar
Welcome aboard Dan
i was wondering when you and your SC would finally get here ....
Dan is quite the author in his own right and I read his stuff in the local papers for years. Great to see after all those car articles written you decided on an SC for your leisure ride
Well It was cooking out last Friday for sure and I stayed in doors. 210 on the motor sounds about right if you ended up in some stop and go traffic but that should not be enought to cause issues. A couple of questions , or comments .
You should not have a plastic hose on the car if it is the line I am thinking of .. The output from the heater blower should be aluminized cardboard and should not melt. The only big plastic duct should run from from the input of the heater blower to a plenum on top left of the engine. The plastic hose may explain the fire.
If your car has AC you should have a restrictor that makes the output heater hose smaller to get by the compressor.
I did have the noise pad fall apart on me too. I did a partial drop, ripped it all out and replaced it sometime later. That stuff gets EVERYWHERE so the sooner you rip it out the better. On mine it sucked it into the engine by the cooling fan and it got stuck on top of the engine as it was sticky from an oil leak.
Better to clean it all up if you can.
BTW Dan it is customary to post pics of your ride when you join or we will really have to haze you ..
As you know I have my 78 sc ( " Project 78 SC Targa" you may know it as ) out in Toronto quite often at the Satuday morning get together at our top secret location behind chapters on the queensway ... DOH ..!
Come down any time and we can compare notes and swap stories...
So again a big welcome to Rennlist .. and don't forget to check out the canadian forum in the "jump to " section on the left.
78 SC Targa
76 XS360
95 Audi 90 Sport
09 Maxima
Gone but not forgotten
87 944S
" I'm not very smart but I know how to google "
theiceman is offline   Reply With Quote
Old 08-18-2009, 08:49 PM   #5
theiceman
theiceman's Avatar
Quote:
Originally Posted by Daniel Dudley View Post
No gas leak ?
did he SAY Carrera ?
78 SC Targa
76 XS360
95 Audi 90 Sport
09 Maxima
87 944S
Old 08-18-2009, 08:51 PM   #6
theiceman
theiceman's Avatar
somehow you ended up with a double post Dan . After reading your other one I suspect your sound deadening pad ignited and caused the other damage. Hope it isn't oo bad ...
78 SC Targa
76 XS360
95 Audi 90 Sport
09 Maxima
87 944S
Old 08-18-2009, 08:52 PM   #7
slownrusty
User
slownrusty's Avatar
Dan - Are you related to Jeff Berdin?
slownrusty is offline   Reply With Quote
Old 08-18-2009, 09:39 PM   #8
dan proudfoot
Default FROM DAN PROUDFOOT
Thanks to all for your replies.
The 'plastic' hose from the heater blower was stock. Only difference I can see is that my mechanic charged $50-plus Cdn. for the replacement part whereas I see it on Pelican for $3-plus.
I remain mystified.
As for the note from the Toronto area SC enthusiast, I am really happy you've got in touch; however, I will be out of town the next couple of weeks, otherwise hope to make it to the secret location behind Chapters.
Dan Proudfoot
Old 08-18-2009, 11:53 PM   #9
rusnak
Hi Dan, and Welcome.
I can't imagine air from the heater causing a fire. The ignition source was electrical, or gas.
I also think 215F oil temp is way too hot in 90F ambient heat. Were you running your heater blower to push air through the heat exchangers? This is a good technique to deal with high engine heat. Perhaps the heater motor is going bad. Sometimes an electrical motor will actually catch fire if it is going bad. The coil can get hot enough to start a fire.
I think the blower also blows toward the rear, but I can be wrong about that. I would probably buy parts myself in the future, rather than go back to the same guy.
I run from earth-crossing asteroids...or from cross, earthy women on steroids.
rusnak is offline   Reply With Quote
Tags
911, 964, berdin, blower, compartment, engine, fire, forum, heater, hot, jeff, maxima, motor, oo, porsche
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
