Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 911 Forum
Old 10-19-2009, 03:24 PM   #1
rusnak
Default Penetrating Oil
I thought that it would be interesting to post a thread about penetraing oil (sorry if one already exists) because I've been experimenting with some of the newer ones out there due to a squeak in my rear anti-roll bar, and with stiction issues relating to the recent rubber bushing replacement (Weltmeister) that I did this past summer.
My friend Mitch also forwarded this interesting email to me, which I took the liberty to cut and paste:
-------------------------------------------email note-----------------------------------
"For those of us who do our own restoration work, here's some interesting comparisons on penetrating oils sent by a friend.
Happy knuckle busting !
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! They are below, as forwarded by an ex-student and professional machinist, Bud Baker.
They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oil ..... Average load*
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ............. 214 pounds
Liquid Wrench ..... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price. "
-----------------------------------end note-----------------------------------------
My current favorite penetrating oils for breaking free rusty bolts are:
brake fluid (just drip it on with a screwdriver);
PB Blaster;
Tri-Flow (the liquid one);
Corrosion X (this stuff is really good and does not leave a residue);
Corrosion X works well on metal to metal applications such as door hinges, radio antenna, hood latch, etc.
Sometimes a spray lube works well, such as on GM truck hood hinges. In these heavy duty applications, and on door striker plates, I use a spray-on lube made by Bel-Ray. It's their chain lube with molyphos
http://www.google.com/product_url?q=...hl=en&sa=title
I run from earth-crossing asteroids...or from cross, earthy women on steroids.
rusnak is offline   Reply With Quote
Old 10-20-2009, 06:16 PM   #2
cal44
cal44's Avatar
I've been using Kano forever. They also (off topic) have a fuel additive that seems to well.
Sports.... Opiate of Fools
cal44 is offline   Reply With Quote
Old 10-20-2009, 07:01 PM   #3
Roc Doc
User
Roc Doc's Avatar
Those results are interesting. Me? I've never had much luck with WD-40 (which is mostly kerosene), but PB blaster has always worked great. But then again I live where rust is not an issue.
The ATF/Acetone is interesting. I wonder if it makes a difference between Mercon and Dextron?
Roc Doc is offline   Reply With Quote
Old 10-20-2009, 08:56 PM   #4
jakeflyer
User
jakeflyer's Avatar
I am going to try the atf/acetone. PB works well. used to use marvel.
jakeflyer is offline   Reply With Quote
Old 10-20-2009, 08:58 PM   #5
theiceman
theiceman's Avatar
Acetone is brutaly harsh , don't splash any ..
78 SC Targa
76 XS360
95 Audi 90 Sport
09 Maxima
Gone but not forgotten
87 944S
" I'm not very smart but I know how to google "
theiceman is offline   Reply With Quote
Old 10-20-2009, 11:55 PM   #6
WPOZZZ
WPOZZZ's Avatar
Do you have test results for Zepreserve?
86 930 turbo, 3.4, K29, sc cams, B&B headers/exhaust/IC...
80 911 Weissach
01 4Runner, TRD sc'd
03 CLK500
WPOZZZ is offline   Reply With Quote
Old 10-21-2009, 01:42 AM   #7
Ed Hughes
Ed Hughes's Avatar
I've never been all that impressed by PB. The numbers seem to bear this as true-not much better than WD40. I'm going back to Liquid Wrench (I remember my dad using this in the 60's) as that is a significant improvement.
I'd be interested in the home brew, but it is hard to argue the convenience of pre-canned either aerosol or spout.
Ed Hughes
1984 911 "Ruby" (TrackTarga™)
COMING SOON in 2010: The New/Improved Ruby!
Ed Hughes is offline   Reply With Quote
Old 10-21-2009, 09:47 AM   #8
amjf088
amjf088's Avatar
Hey Rus...
Did your friend indicate how many trials of each were used to determine the average?
Very interesting...
1985 911 Carrera: The fun car
1987 944 S: The project car
2002 Subaru WRX: The daily car
Visit My P-Car Projects!
amjf088 is offline   Reply With Quote
Old 10-21-2009, 02:14 PM   #9
rusnak
Hi amf,
No he did not, but he knows some very good machinists. They are amazing dudes, so I trust their results.
I want to try to find the Kano stuff.
Old 10-21-2009, 02:19 PM   #10
SeanR
SeanR's Avatar
Send a message via Yahoo to SeanR
www.kanolabs.com
It's great stuff.
http://www.928srus.com/
Anotherplace
'88 S4
•• Law of Mechanical Repair - After your hands become coated with grease, your nose will begin to itch and you'll have to pee.
SeanR is offline   Reply With Quote
Old 10-22-2009, 12:22 AM   #11
Ed Hughes
Ed Hughes's Avatar
Quote:
Originally Posted by SeanR View Post
www.kanolabs.com
It's great stuff.
I'll have to try this then.
I still have to get a replacement set of oxy-acetylene tanks. I've not unpacked my torches since I got back to Calif. Heat is still the ultimate loosening agent.
PS- Getting closer to my trip to DFW and my day at MSR!
Ed Hughes
Old 10-22-2009, 12:36 AM   #12
SeanR
SeanR's Avatar
It seems to be some good stuff. I like it better than PB. I really need to do the other home brew mix but that will wait until I'm out of the Kroil.
Ed, looking forward to it, how much luggage space do you have?
Anotherplace
'88 S4
Old 10-22-2009, 12:40 AM   #13
Ed Hughes
Ed Hughes's Avatar
Ha! Not enough for what you're thinking.
Ed Hughes
Old 10-22-2009, 12:43 AM   #14
SeanR
SeanR's Avatar
Anotherplace
'88 S4
Old 10-23-2009, 06:37 PM   #15
randywebb
randywebb's Avatar
Quote:
I would never use Acetone anywhere without a laboratory hood
it is extremely toxic
Sure, my car is period correct -- but which period depends on what part of the car you are looking at...
randywebb is offline   Reply With Quote
Tags
40, 88, comparison, comparisons, difference, kb, kroil, marvel, oil, penetrating, peter, rust, tested, wd, zimmermann
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
