Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 911 Forum
Old 10-27-2009, 04:09 PM   #1
914v8porjekt
User
914v8porjekt's Avatar
Default Warmup Regulator Victory!
I recently was working on a 2.7L CIS Car. It sat for more than 10 years. Needless to say there were alot of things that it needed. Fortunately it still had good compression and was able to start her up. After a new tank, fuel pump, fuel filter, cleaned the fuel distributer, new wires, new sparks plugs. However it had a very bad miss at cold startups all the way until it would finally warm up to 180F. But it still showed some misfires sometimes. I did alot of research to see what could be wrong. I drew the conclusion that the car was running VERY lean because of the backfiring through the exhaust, no black smoke from being rich, and the temps would continue to increase to 220. Not to mention that the car would eventually run better once warmup,making sense because as the car warms up, the control pressure should go up. But mine was always high because the WUR was not able to bleed off control pressure back to the tank at cold because of the clogged inlet of the WUR.
Since the car was suspiciously running lean. I decided to take off the Warmup regulator to see if it was clogged and not letting control pressures leak off during cold to warmup periods. Sure enough I found the inlet for the control pressure line semi clogged and I cleaned her up good with carb cleaner. I did not mess with "knocking plugs in or out" because i figured that since the car ran before it was parked, the control pressures would be ok once it cleaned up.
Sure enough when I put everything back together, the car started up and ran perfect!!!!! Cold starting issues completely gone and lots of power without misfires or hesitation all the way up to warm. And guess what, no more overheating.
Just wanted to share this because there may be some people experiencing the same problems from a simple clogged WUR.
914v8porjekt is offline   Reply With Quote
Old 10-27-2009, 05:33 PM   #2
butzip
butzip's Avatar
Nice, good work and thanks for sharing!!
butzip is offline   Reply With Quote
Old 10-28-2009, 01:08 AM   #3
Houpty GT
User
Houpty GT's Avatar
My car had the same problem. The fuel screen in the WUR was clogged with what looked like rust. I just wish I could say that it was all that was wrong
I believe I found mine when I saw that there was no difference between the control pressure and the system pressure.
Houpty GT is offline   Reply With Quote
Old 10-28-2009, 11:21 AM   #4
wpriller
wpriller's Avatar
I would suggest somewhere down the line to change the wur to the UnwiredTools UTCIS management system. I replaced my wur with the UTCIS unit and it works like a champ. Definitely no more starting problems or vapor lock. Good to hear that you were able to solve the problem. www.unwiredtools.com/utcis.asp
wpriller is offline   Reply With Quote
Old 11-04-2009, 06:05 PM   #5
Brett San Diego
User
Brett San Diego's Avatar
Good information. Thanks for posting.
Brett
Brett San Diego is offline   Reply With Quote
Tags
924, porsche, regulator, service, warm
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
