Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 911 Forum
Old 11-06-2009, 10:53 PM   #1
RSWiser
User
Default Oil Temp Questions
My 80 SC is finally running great. Changed the oil return line that was leaking, fixed the power windows, new brake pads and front bearing.
Today I drove on the freeway for a while watching the oil gauges. The Oil level gauge stays above the red, sometimes higher than others. The Temp gauge goes up slightly but never more than barely above the line. Never high.
I have one of those tempature gauges that you point at the item and it give you the temp. Where should I take measure the tempature? I want to make sure I am not getting hot.
Also after a good drive when I park the car in the garage it smells like hot oil. Never in the car just in the garage after, is this normal.
Thanks,
Rob
RSWiser is offline   Reply With Quote
Old 11-06-2009, 11:04 PM   #2
theiceman
theiceman's Avatar
it all sounds pretty normal ..
1. The oil level guage means nothing while driving and is only used while idliling engine fully warmed. Everyone will tell you use the dip stick to check and this is good advice . Although mine is dead accurate as to oil level under the above conditions. If you are in doubt a new sender will fix it .
2. Oil temp , just above the first mark is fine. I also have a laser temp monitor and without a reference this means nothng . The oil temp is only at the tip of the probe. nywhere you check you would have to have someone else check to see if it is close . I have a 78sc so I could check , but it is currently 0c here so it would be way different.
3. Your hot oil smell is a leak onto your heat exchangers . Not a huge deal and mine does this also after hard driving with high revs . no biggie if it is not smoking.
78 SC Targa
76 XS360
95 Audi 90 Sport
09 Maxima
Gone but not forgotten
87 944S
" I'm not very smart but I know how to google "
theiceman is offline   Reply With Quote
Old 11-06-2009, 11:08 PM   #3
RSWiser
User
Thanks for the info. No smoking, no visible leaks to the ground. I'll check the top of the exchanges.
Rob
Old 11-06-2009, 11:09 PM   #4
theiceman
theiceman's Avatar
Yeah Rob mine is the same .. nothing ever hits the ground ..
78 SC Targa
76 XS360
95 Audi 90 Sport
09 Maxima
87 944S
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
