911 Forum 1964-1989
One Very Cool 911
Old 01-03-2010, 09:45 PM
MJones
MJones's Avatar
Default One Very Cool 911
"King of the Hill" RSR
Interesting Story
What happened to the Mulholland "King of the Hill" RSR?
Old 01-03-2010, 10:13 PM
HkPlinker
HkPlinker's Avatar
Love it. It looks like a Hot Wheels car!
Old 01-03-2010, 10:52 PM
dshepp806
dshepp806's Avatar
MAN,..THAT looks badass...........
Old 01-03-2010, 11:01 PM
jwilson95
jwilson95's Avatar
Love the chop top
Read about it in Excellence.
Old 01-03-2010, 11:36 PM
mholbrook38
mholbrook38's Avatar
The link above is a Pelican link and probably the longest link in existance. Very interesting story if you have a couple days to read it...
Old 01-04-2010, 04:01 PM
MJones
MJones's Avatar
A little about the car at post #703
what-happened-mulholland-king-hill-rsr-36.html
If you look carefully, you can see some of the body modifications. Cut drip rails, Turbo body style, large whale tail, 9 and 11 inch alloys with Good Year Racing Tires, and of course the famous sloped roof. You will also notice a silver colored rollcage. That is T6 alloy, twice as strong as steel in compression strength, with one-fifth the weight. It was designed and built by John Mason Engineering at quite a cost. The rollcage extends from the rear of the car to the front and forms a kind of tubular chassis.
The cage is gusseted to all chassis members such as the rear deck, the four window pillars, floor mounts and integrated into the entire dashboard.
Shock tower bracing was added front and back and the whole car was full-seam welded for maximum ridgidity. There is NO body flex in this superlight acid dipped chassis.
Of course, full RSR suspension is installed to suck up all the bumps Mulholland has to offer. This includes: double adj. Konis that are adjustble for bounce and rebound with dials on the side of the shock, oversize Porsche RSR torsion bars to increase spring rate to suck up potholes at speed, special spring plates set in solid Delrin bushings to prevent geometry changes while cornering, gusseted and magnefluxed trailing arms set in solid bushings, and oversized RSR anti-roll bars also in solid bushings.
It has 906 brakes with cross-drilled and vented rotors combined with alloy calipers and stainless steel brake-lines for maximum stopping power.
This suspension combined with nine and eleven inch wide wheels covered with Blue Streaks makes for quite formidible handling.
The powerplant is a hi-compression RSR 2.8 ltr. mfi racing engine.
Complete with RSR sprint cams, ported and polished heads, an R3Y mfi pump, twin plug ignition, cadmium plated sheetmetal, magnefluxed crank and rods, custom exhaust, and of course fully balanced and blueprinted.
The motor and transmission were built by Bozzani Racing. The transmission is a magnesium cased 915 racing gearbox with a 85% limited slip and "Riverside" Gears. The car has a 16 quart dry sump lubrication system that pumps oil from the rear of the car to the front where an aluminum tank is located inside the gas heater trunk. All oil lines are teflon braided stainless steel and travel throughout the car. The tank which was made by John Mason is wedge shaped to prevent grabbing air in hard cornering, baffled to prevent foaming of the oil, and vented for crankcase ventilation. It also combines a remote oil filter with a thermostat that opens to an external oil cooler when neccessary.
The interior is spartan with flat door panels and no glove box door. The 10,000 rpm tachometer redlines at 8500 and the speedometer shows a top speed of 185mph. The seats are Scheel Nomex racing deep buckets that are flameproof. Leather Recaro sport seats are also used for the car. Bright H4 headlights illumimate Mulholland when neccessary.
I thought some of you might like to know the basic modifications made to the car.
Old 01-04-2010, 05:01 PM
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
The seat is so low he can't see over the dash.
Old 01-04-2010, 05:59 PM
MJones
MJones's Avatar
Old 01-04-2010, 08:05 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
That is some thread! Read about the first 17 pages. Good stuff!
Old 01-04-2010, 08:12 PM
Quadcammer
Quadcammer's Avatar
Received 1,372 Likes on 794 Posts
love the car, not the wheels or the tires.
Old 01-04-2010, 08:22 PM
rusnak
I haddah Google dat
rusnak's Avatar
He's driving with the hood open.
Old 01-04-2010, 08:44 PM
MUSSBERGER
uninformed gas bag
MUSSBERGER's Avatar
maroons
Old 01-05-2010, 12:57 AM
Ed Hughes
Ed Hughes's Avatar
It's called old school, and I'm sure is representative of its look back in the day-I believe he ran on slicks, which is probably the reason for the big Goodyear lettering....besides there's nothing wrong with classic Fuchs with polished petals. I think the entire package is cool
Old 01-05-2010, 01:53 AM
MJones
MJones's Avatar
The car is a time capsule...same owner since the 70's and has less than 5,000 mi.
Quote from the owner:
I have kept it safe all these years and it is in the same configuration as when it was raced in the 70's and early 80's. Time has stood still for the Mulholland Carrera. Almost every if not every Mulholland racer has long ago let go of their Mulholland race-car. I cannot. The Carrera is part of the family and it will not leave Mulholland, for it belongs to the lore, mystery, and legend of that famous Drive.
Car sat idle from 1994 (Northridge Earthquake) till 2007, previous video.
The Pelican thread is like a history book of Mulholland it's history and lore ...only 267 pages...
If you lived in LA check it out, if not check it out
Old 01-05-2010, 02:01 PM
whalebird
whalebird's Avatar
Love the car and the movie. Thanks Mjones for linking the videos although they are not the best quality.
Quick Reply: One Very Cool 911
