911 Forum 1964-1989
Finally Starting my 3.2 to 3.4 Conversion
Old 11-21-2013, 03:29 PM
  #136
ClubsportSP
ClubsportSP's Avatar
Originally Posted by rare911s
What is WHP on a 3.2 with SSI's single plug on average, 91 oct?
265-270 ish?
Mine on standard exhaust running 99ron (UK) single plug at 10.45:1CR hits 273 fwhp
Ssi are meant to be marginal on 3.2, more so on 3.4 - for outright fwhp at least. Torque I imagine is different
Old 11-21-2013, 05:39 PM
  #137
Ed Hughes
Ed Hughes's Avatar
Originally Posted by ClubsportSP
265-270 ish?
That is quite optimistic.
Old 11-22-2013, 07:41 AM
  #138
ClubsportSP
265-270 or my own figures?
Old 11-22-2013, 08:59 AM
  #139
redridge
redridge's Avatar
Are these numbers from a clubsport 911?
Old 11-22-2013, 11:09 AM
  #140
ClubsportSP
Nope, that was my estimate of the question asked a few posts ago re fwhp
My previous car was a Clubsport, hence the tag. This was a 3.2 with SW chip
My current car is a 3.4 running 98mm Mahle p and c, single plug, dc20 cams, SRP valve gear and sports 1in1out pre/main silencer = 273fwhp/245 lbft
Have now installed 1 5/8" headers and a dmeshop24.de MAF and keen to know what it's pushing
Old 11-22-2013, 12:06 PM
  #141
Ed Hughes
Ed Hughes's Avatar
The estimate. I don't know what "whp" is. I know FWHP and RWHP are.
With 1 5/8" headers (not SSI's) and a SW chip running 93, I dyno'd at about 205 rwhp with a stock US 3.2. Other than the octane and that I was running larger headers, I think this is the config the poster asked about.
Old 11-22-2013, 03:20 PM
  #142
ClubsportSP
You're right Ed, my bad - i read it as a quote on a 3.4
Old 11-22-2013, 03:28 PM
  #143
AC/911's
AC/911's's Avatar
Ed, what headers are you running, do they have heat?
This is what a 3.4 Twin plug did with SSI's, 91oct, I expected more........
Old 11-22-2013, 04:48 PM
  #144
Ed Hughes
Ed Hughes's Avatar
I'd say that depends on compression, cams, etc. I went at 230-something at the wheels with all stock intake. They WERE 1 5/8" B&B headers (not muffler!!) with heat.
Old 12-19-2013, 06:13 AM
  #145
slow car
slow car's Avatar
Looking for a set of 98mm 10.5:1 piston and barrel set if any one has a set for sale to upgrade my 3t to 3.2
Old 12-19-2013, 09:48 AM
  #146
Ed Hughes
Ed Hughes's Avatar
Your 98mm pistons and the ones to go from 3.2 to 3.4L are NOT the same....
Old 12-20-2013, 09:21 AM
  #147
pojefferson
pojefferson's Avatar
I did a 3.2 to 3.4 with:
- 98mm 9.5:1
- stock intake
- headers by RarelyL8 (with their heater boxes); 1 5/8" OD
- Dansk Sport 2in:1out muffler
- 964 grind camshaft set
- twin ignition
- corresponding Steve Wong Chip; inc. 94 octane
I got 225 at the wheels on a Dyno Dynamics w/ everything above minus the exhaust config; i.e. I had stock 3.2 heat-exchangers, Dansk Sport muffler and cat-bypass. I have not yet retested with the different exhaust, however if I had to do it again (or if I get another chance), I would go with higher compression: 10.5:1 or 11:1.
Philip
Last edited by pojefferson; 12-20-2013 at 09:32 AM. Reason: correct mis-information
Old 12-20-2013, 11:58 AM
  #148
Ed Hughes
Ed Hughes's Avatar
You missed on the compression opportunity, and I'd think the single out muffler isn't doing you any good. I actually made a cap for one of the pipes on my flowmaster to quiet it up, when needed. I dyno'd with and without, and IIRC, there was a 7HP difference.
- 98mm 9.5:1
- stock intake
- twin ignition
Philip
Old 12-20-2013, 05:00 PM
  #149
pojefferson
Yes, 'missed' - but easily rectified with money. I opted for single outlet just because I don't like the 'look' of dual-outlet on my year; and I wasn't interested in the 'sound' while driving around my neighborhood. But, at least now I know more quantitatively what I'm missing ;-)
Quick Reply: Finally Starting my 3.2 to 3.4 Conversion
