911 Forum 1964-1989
Finally Starting my 3.2 to 3.4 Conversion
Old 01-29-2010, 10:54 AM
Dentron
Dentron's Avatar
Default Finally Starting my 3.2 to 3.4 Conversion
I'm finally starting my 3.2 to 3.4 conversion as a result of my valve guides needing replacement and the anticipation of the #8 seal potentially leaking on the bottom end. The 3.4 Mahle Pistons were not easy to find.
http://www.pcars.us/albums/15774_C_L..._4_Rebuild.jpg
Old 01-29-2010, 12:40 PM
Brett San Diego
Brett San Diego's Avatar
Right on! If this is all DIY, please keep up with the pics. Nice spread to start out with.
Brett
Old 01-29-2010, 01:06 PM
Dentron
Dentron's Avatar
The casing still needs to be polished, but you can see where # 8 would begin leaking soon due to seals that were not that great in 87 and the wear due to mileage of course.
Old 01-29-2010, 03:05 PM
rusnak
I haddah Google dat
rusnak's Avatar
Nice! Can you let us know which parts you will be changing from stock, and what you've learned about them? Thanks!
Old 01-29-2010, 03:24 PM
Dentron
Dentron's Avatar
I sure will.
Old 01-30-2010, 12:38 AM
Ed Hughes
Ed Hughes's Avatar
I'm doing the same thing, but I don't have to split my case. I walked into Andial in Fountain Valley recently and bought a set of high compression 3.4's off the shelf. They also had a set of stock compression at the time. Why did you have trouble finding them?
Old 01-30-2010, 01:18 AM
Dentron
Dentron's Avatar
Hi Ed,
I was specifically looking for Mahle 98mm 9.8:1 Piston and Cyl Set, and I was basically looking for a specific price point.
I actually didn't have to open my case, but since I had the engine down this far I wanted to replace all of the seals, and bearings, on the bottom end to prevent any potential cold leaks down the road especially from # 8. I figured I'd take the engine down one time to try and avoid having an annoying slow leak in the future.
Old 01-30-2010, 10:19 AM
whalebird
whalebird's Avatar
Sweet 3.4 projects going on in So. Cal. Wish I were there. I could make the rounds with a case of beer and stay updated weekly.
Dentron, Isthat a 3.6 lay-shaft(oil pump drive)?
Old 01-30-2010, 11:52 AM
Ed Hughes
Ed Hughes's Avatar
I don't blame you for going through the case. I had done mine 2 years ago, and feel it is fine. I was pretty amazed I could get my Mahle goodies for JE prices-sign of the times.
Old 01-30-2010, 12:05 PM
Dentron
Dentron's Avatar
Yep, that's for sure. A guy also owed me a favor so that helped a lot.
I'll keep you guys posted.
Old 01-31-2010, 12:06 AM
Dentron
Dentron's Avatar
No Actually 3.2. 3.6 is a steel shaft instead of an aluminum shaft like mine.
C.L.
Old 01-31-2010, 12:09 AM
Dentron
Dentron's Avatar
Putting a bigger Cam in. Not too big so it doesn't kill my smog capabilities.
Old Cam
911SC
Intake Exhaust
Duration Duration
(Deg) 229 (Deg) 220
Lift Lift
(In) .455 (in) .402
Lobe Center
(Deg) 113
New Cam
Old 01-31-2010, 03:13 AM
TT Oversteer
TT Oversteer's Avatar
What cam manufacturer are you going with?
Regrind yours or new billet?
How did you decide on that particular profile?
I'm planning a valve job on my 3.2 with new rings if the P's and C's measure out ok. Also considering 964 cams but looking into other profiles that will pass CA smog.
Thanks for sharing your build. I'd like to go 3.4 with new jugs too and dual plugging as Ed is doing.........but...........gotta stop the madness and draw the line somewhere!
Old 01-31-2010, 04:46 AM
Dentron
Dentron's Avatar
Actually that was the most aggressive I wanted to be and still be able to smog the car.
Old 01-31-2010, 03:18 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,043 Likes on 742 Posts
Hey Dentron I have heard much about this #8 seal leak but not sure exactly where it is .. would you mind posting your case pic with an arrow pointing to it ?
thanks
Quick Reply: Finally Starting my 3.2 to 3.4 Conversion
