1972 911 door handle lever replacement
Ouch! It's probably been 25 years since I've seen the problem, but I seem to remember that the pot metal lever, or a piece of it. breaks off and you need a replacement handle assembly that you can transfer your lock/tumbler assembly over to.
+1 on the replacement handle. That pot metal can't be fixed. See if someone has a used one and change the lock out. I suggest a picture of your old one so whoever might have one can view it and make sure.
Best,
Doyle
I haddah Google dat
Ah, yes that's it. Before you order, be SURE to take the old one out and have a look, since there are two styles of exterior door handle triggers. They are not all the same.
