Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 911 Forum
Sign in using an external account
Register Forgot Password?
Search
This Rennlist Forum is sponsored by Intercity Lines
Thread Tools Search this Thread
Old 12-21-2010, 11:03 AM   #1
ivangene
Parts Specialist
Default intermittent wiper rheostat troubleshooting
well as the title suggests, I would like to know how to troubleshoot the rheostat for the intermittent wipers
A search yields a few posts but no real info, the bentley just tells me how to replace it and at well over $100 i dont want to start replacing good parts.
The symptoms: wipers work perfect on the stalk control but have started to have occational stopping mid-wipe while in intermittent mode - thought maybe I could clean the thing, but if I take it out I wanna know how to check it out.
are there more parts involved (ie a control unit/relay/ect) that might be suspect.
This is not going to need emergency repairs, but I would like to keep up as we all know little things can end up being overwhelming at some point
Thanks Guys.
To remove this ad, register today or login if you already are registered!
ivangene is offline   Reply With Quote
Old 12-21-2010, 12:08 PM   #2
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Why, get much rain?
Marc Gelefsky
02 996 Coupe 6 Speed Aero
86 911 Carrera Targa
04 Cayenne S "!"
04 Audi Allroad 2.7T 6 Speed - Wife's Ride
Gone - 88 951, 87 951, 86 944na, 85.5 944na x2, 01 Boxster S
http://typ911.com/marcg996.jpg
Marc Gelefsky is offline   Reply With Quote
Old 12-21-2010, 12:09 PM   #3
ivangene
Parts Specialist
we have switched from the old "inch" measuring method to the new "feet" method
Old 12-21-2010, 12:28 PM   #4
Marc Gelefsky
Super Moderator
geeez!!
We just have ccccccccccold!
Marc Gelefsky
04 Cayenne S "!"
Old 12-21-2010, 12:31 PM   #5
KILRWAIL
KILRWAIL's Avatar
From the workshop manual current flow diagram, there is a relay as well as the switch. Good luck tracing the problem!
Peter
1977 Porsche 911S - track car
1978 Fiat 124 Sport Spider - original owner
2002 Dodge Ram 4 x 4 - hauler
PCA National Instructor
KILRWAIL is offline   Reply With Quote
Old 12-21-2010, 12:41 PM   #6
theiceman
Super User
theiceman's Avatar
Clive Young icemanxo theiceman911
i have never had the WW system out of the Porsche but on other cars I have done there have been microswitches in the motor asembly . This tells the wiper system the arms have returned to home. Not sure about the Porsche though. Even though I would go here last .. don't discount the motor as being the cause . In full on mode it would not even look at these switches until you turned it off then it would look to go home. on intermitent it looks to go home every time until it is told to go again . I don't know anything for a fact this is just an opinion ..
theiceman is offline   Reply With Quote
Old 12-21-2010, 12:56 PM   #7
3.2 Targa
Pig hunter
3.2 Targa's Avatar
Mine does a similar thing when the wipers move from the stopped position. I would describe it as a hiccup.
I think my issue may be a relay based on the hiccup timing.
Scott C.
1989 Targa
2008 Cayenne GTS - 6MT
2008 Lexus IS350
1999 K2500 Chebby Subdivision
3.2 Targa is offline   Reply With Quote
Old 12-21-2010, 01:02 PM   #8
Marc Gelefsky
Super Moderator
I am pretty sure it was the relay when I fixed this on my 86... around 10 years ago.
Marc Gelefsky
04 Cayenne S "!"
Old 12-21-2010, 01:08 PM   #9
ivangene
Parts Specialist
If they hiccupped on the "ON" mode I would suspect the main switch OR the motor, and if they didnt return home or just stopped wherever the switch was turned off I would look at the motor...
in my case all is well - in fact perfect, just that when using intermittent I am getting the occational STOP mid-wipe (like the power has been cut) then re-starts...They seem to re-start faster if I sweet talk them (yelling only made them stay off lonkger)
The last useful thread RE this issue saw from 2002 so I didnt jump start it as none of the posters were active anymore on this board - Hope to find out and pass along the info
Marc, Relay is other than the rheostat? (sounds cheaper too)?
Old 12-21-2010, 02:58 PM   #10
ivangene
Parts Specialist
I keep learning stuff...
so I found a part on the wiring diagram says "Right (and left) Heated Spray Jet"
For the wiper washers?
WOW - anyone know how to tell if those work and what temp the water is heated too?
Anyhoe in 85 the circuit is very differant than 86' I will check exactly which I have but it looks like there is something called "wiper intermittant control unit" if that is the issue, its some sort of "black box" - no data shown as to what's going on in there - keep ya posted
Old 01-29-2011, 01:09 PM   #11
ivangene
Parts Specialist
update:
problem not solved, but I know where the problem is.... its the steering wheel wiper assy.
When the intermittent wipers stop it is due to the control unit not recieving power from the steering wheel switches/assy - if I apply the very lightest presure to the lever, it makes contact and the intermittent wipers are 100% perfect....I checked by wrapping a loosely fitted rubber band between the wiper and cruise levers and the problem is gone... now to replace that thing when time/money permits. (the list is bigger then the wallet, so I have to work them down)
Paid Advertisement
Tags
124, 855, 944, 996, fiat, intermittent, motor, porsche, problem, replacing, rheostat, troubleshoot, troubleshooting, wiper, wipers, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
