911 Forum 1964-1989
Fuel Additive for Ethanol
Old 05-18-2011, 11:51 AM
hbtd
hbtd's Avatar
Default Fuel Additive for Ethanol
My mechanic recommended Stabil Marine Formula to run in the 911. He said the marine version has more additives to fight the ethanol effects in an older "weekend" car.
Anyone else use an additive for ethanol?
Old 05-18-2011, 12:11 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,026 Likes on 730 Posts
i run the marine stabil . but only as a stabilizer over the winter .. i would question the 'weakened" comment .. unqualified statement
Old 05-19-2011, 03:42 PM
Ian Ledger
Ian Ledger's Avatar
I do not understand the reference to Ethanol, it is a good co-solvent, and is good for drying fuel systems. I suppose this refers to the hydrophilic properties of ethanol, which are problematic on storage.?
Ian
Old 05-19-2011, 04:10 PM
911Dave
911Dave's Avatar
Ian, yes, the use of Stabil helps to prevent the absorption of water, which is a problem that's even worse when the gas contains ethanol.
Old 05-19-2011, 04:46 PM
mongrelcat
mongrelcat's Avatar
Just find an ethanol-free station near you --
http://pure-gas.org/index.jsp?stateprov=GA
Old 05-19-2011, 05:20 PM
rusnak
I haddah Google dat
rusnak's Avatar
An old bunson burner won't even light, such is the absorbtion of water from the air.
Old 05-19-2011, 05:25 PM
SpeedBump
Happily Amused
SpeedBump's Avatar
If only it were that easy. I would have to fill up again by the time I drove home from the closest station on that site.
Old 05-19-2011, 05:39 PM
g-50cab
g-50cab's Avatar
Google "phase separation" Bad juju for all engines when any gas sits for extended periods of time - but ethanol is the worst.
Ethanol - good for corn lobbyists and the senators they support - good for engine repair shops and small engine builders and dealers (leafblower runs bad, most replace, not fix)
Bad for everybody else.
Old 05-19-2011, 08:44 PM
dshepp806
dshepp806's Avatar
I buy 93 octane gas with NO ethanol..(luckily)...hopefully it will remain that way!!!!!!!!!!
Doyle
Old 05-19-2011, 08:50 PM
dshepp806
dshepp806's Avatar
nice URL,..thanks!
Doyle
Old 05-20-2011, 12:27 AM
The Brewmeister
The Brewmeister's Avatar
Ethanol... what a bunch of pure bureaucratic BS! I hate politicians...
Old 05-20-2011, 02:18 PM
Helios59
Helios59's Avatar
We're in the same boat...here in Silver Spring there ain't no choice. All the ethanol-free places are a tankful away.
Old 05-20-2011, 02:27 PM
aj986s
aj986s's Avatar
Another product:
http://www.starbrite.com/sproductdetail.cfm?ID=1537
My tuning mechanic recommended this one. He periodically tests the fuel used in his customer's race cars, for alchohol and water content. He says the Starbrite product works well to deter water accumulation.
Old 05-20-2011, 05:27 PM
GothingNC
GothingNC's Avatar
Originally Posted by aj986s
Another product:
I'll have to try it out.
Most of the marine stores in my area stock it on the shelf.
Old 05-22-2011, 04:30 PM
Helios59
Helios59's Avatar
If your car's a year-round driver...say you take it out every weekend or second weekend even in winter..does it still need some sort of fuel stabilizer?
Quick Reply: Fuel Additive for Ethanol
