Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 911 Forum
Sign in using an external account
Register Forgot Password?
This Rennlist Forum is sponsored by Intercity Lines
Thread Tools Search this Thread
Old 02-06-2012, 12:55 PM   #1
vinyl_tien
vinyl_tien
Send a message via Skype™ to vinyl_tien
Default Which is better 3.0 or 3.2 L for 3.8L
I am consider build a 3.8 L engine, a 3.2 and 3.0 engine, which one will be a good platform?
Need you guys advice! Many thanks!
vinyl_tien is offline   Reply With Quote
Old 02-10-2012, 06:20 PM   #2
porsche0nut
porsche0nut's Avatar
jonathanjbrooks jonathanjbrooks porsche0monkey
I've heard of builds of 3.4 and 3.5L, starting with a 3.2 base, but never a 3.8. I think it would be very difficult to make the cylinders that large and still have enough wall strength.
Why 3.8L?
Take a look at the forum "Impact Bumpers". There are a lot of engine build threads on there starting with 3.0 and 3.2L engines.
Whatever you end up doing, make sure you document it here with lots of pics! Good luck.
Jonathan
86 911 Coupe
porsche0nut is offline   Reply With Quote
Old 02-11-2012, 01:51 PM   #3
whalebird
whalebird's Avatar
I would say 3.2 for sure, but 3.8 is big. Twin plug ignition is a must. The chassis you choose to put this motor in will be a factor as well. You may be better served to start with a 3.6 based car/motor. Regardless of the platform you choose, to get the most from your project you will have to address cams, heads, intake and exhaust, as well as transmission type/gearing.
whalebird is offline   Reply With Quote
Old 02-11-2012, 04:47 PM   #4
earlyapex
earlyapex's Avatar
A 3.6L motor would be a much better place to start.
http://jwemotorsports.com/
Eric
1978 911SC, PRC/PCA spec 911
1993 964 RSA
#33 Lifelong copilot
earlyapex is offline   Reply With Quote
Old 02-11-2012, 05:42 PM   #5
NineMeister
NineMeister's Avatar
Fit a 3.6 993 engine. Worked for me: the motor in my G50 Carrera runs Motec, makes 308hp on regular 95 octane fuel and gives 30mpg on a run.
Seriously, it will cost you double to convert a 3.2 engine to 3.5 or 3.6 and you will end up with a lot less power and efficiency against fitting a remapped stock 3.6. Then, if 300hp is not enough for you, tuning the 3.6 engine is a lot more straightforward.
Colin Belton B.Eng.
the NineMeister
www.ninemeister.com
DoppelSpeedMeister - Porsche Club Great Britain Speed Champion 2006 & 2007 (Class 1 winner 2005 - 2008)
1995 993RS CS Speed Yellow, 4.0 litre 450+bhp n/a
1990 964 Cup, signal green VIN 9007, 1990 Championship Winner, aka "Kermit"
1986 911 LHD non-sunroof G50 Carrera Coupe mit 993 engine
2005 996GT3RS-R (work in progress)
1994 968CS Speed Yellow, 430bhp supercharged (now sold)
NineMeister is offline   Reply With Quote
Tags
30, 38, 911, builds, engine, motor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
