911 Forum 1964-1989
Removing trailing arm
Old 06-13-2012, 08:06 PM
Ed Hughes
Ed Hughes's Avatar
The monoballs use snap rings as I recall. Another reason to send Chuck Moreland mobey!
Old 06-15-2012, 07:30 PM
Schabelmj
Schabelmj's Avatar
Thanks everyone for the comments. Indeed, I have the monoballs from Chuck ready to go in. Fortunately, following Ed's good advice, the car is sitting high on a bend pak lift, so I should be able to get my body on a bar. I'll probably go buy some new box ends for this...I don't want to risk stripping a nut with a tired wrench. I'll post back when I've got them freed up. Cheers.
Old 06-15-2012, 08:03 PM
Ed Hughes
Ed Hughes's Avatar
Good luck! You'll get them.
Old 06-18-2012, 08:01 AM
Schabelmj
Schabelmj's Avatar
One out, one to go. I've searched high and low for the perfect tool to get this out. With the transmission in place, there isn't enough room to get a shallow socket in place, but the nut is recessed in the frame just to the point that I couldn't get a wrench on it without stripping the nut. Ultimately, I cut the first one out (very carefully), but there is no room to do that for the left hand side. Last night, I thought i'd try something different. I started cutting a 22mm bolt pattern into the top of the socket. That effectively will extend the nut out by an inch and let me get a wrench on it. I'm off for another week of travel, but hope to find a lathe at the office to finish off my homemade tool and go at it again next weekend.
Old 06-19-2012, 09:15 PM
rusnak
I haddah Google dat
rusnak's Avatar
Can't exactly visualize it, but I can say I looked at mine and said "eff it", drop the motor. You are a brave soul! More encouragement to you.
Old 06-19-2012, 09:44 PM
Ed Hughes
Ed Hughes's Avatar
Some jobs are indeed easier with the engine out. Two hours max, when you're in practice.
Old 06-19-2012, 10:15 PM
User 4221
User 4221's Avatar
Damn.... When I had my engine out a dealer tech advised me to pull those and turn the bolts/nuts around.
Alas, I didn't heed his advise and now I'm not looking forward to this job.
Old 06-19-2012, 11:38 PM
Schabelmj
Schabelmj's Avatar
If my homemade tool doesn't do the trick, I'll drop the motor. Sway bar and axles are already out, so I'm 1/3 of the way there.
Old 06-19-2012, 11:42 PM
Schabelmj
Schabelmj's Avatar
3.2 Targa, I'll check when I'm in there, but I think the bolt is long enough that if you flipped it, it would catch on the transmission such that when you back it off, it wouldn't clear the trailing arm. I'll check though just to be sure and report back this weekend.
Old 06-20-2012, 01:04 AM
User 4221
User 4221's Avatar
Thanks, I think I may have not understood him but I would like to know your findings.
Here's the PET drawing for additional color.
Old 06-20-2012, 01:17 AM
Ed Hughes
Ed Hughes's Avatar
As I recall, the bolts are fairly long.
Old 06-23-2012, 12:17 AM
Schabelmj
Schabelmj's Avatar
Update: I managed to remove the driver's side bolt this evening. That was a tough cookie. The key was using this little tool I machined - which I call my "nut socket". Essentially, I machined a bolt pattern into the top of a short socket. The socket went over the nut that was recessed inside of the frame, and allowed me to then turn the socket using a box end (and a lot of umph) while not banging into the transmission. Once I mount the trailing arms back on, I'm happy to share it with anyone else on the Forum who needs it.
Old 06-23-2012, 01:49 AM
Ed Hughes
Ed Hughes's Avatar
Nice!
Old 06-23-2012, 10:48 AM
User 4221
User 4221's Avatar
If you take tool loaner payments in beer, than I'm in!
Quick Reply: Removing trailing arm
