911 Forum 1964-1989
Sport Shock Option for 87 g50
Old 07-03-2012, 02:29 PM
savantauto
savantauto's Avatar
Default Sport Shock Option for 87 g50
Can anyone please tell me if the factory Sport Shock Option on the 87 Carrera Coupe provided a lower ride height than the standard factory set up?
Old 07-03-2012, 03:45 PM
Amber Gramps
Amber Gramps's Avatar
Are you asking if the spindles are welded higher on the struts?
Raising my spindles 15mm is on my ultimate DIY check list. I have access to the equipment, now I just need access to money. Like that will ever happen.
Old 07-03-2012, 05:03 PM
marcel964
marcel964's Avatar
sport shocks are bilstein on a 87 car, standard shocks were boge. Ride height is the same, but more firm
Old 07-03-2012, 10:48 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,044 Likes on 743 Posts
Short answer no
Long answer. Ride height is traditionally determined by changing the springs on a conventional car. On our panzers it is set by reindexing torsion bars and adjusting spring plates.
Old 07-07-2012, 12:29 AM
syzygy
syzygy's Avatar
Actually, if one only switches from Boge to Bilsteins, the ride height will likely increase a little bit.
Old 07-07-2012, 03:54 AM
marcel964
marcel964's Avatar
My 87 had it from The factory. Last year it got à fresh set all around. Rightheight compared to other is The same, but handeling is so much better. Espaccialy with turbo tie Rods.
But if your car doesnt have it standard, look very carefully what you buy, cause, standard bilstein doesnt fit in standard boge.
Old 07-07-2012, 09:48 AM
Bill Verburg
Bill Verburg's Avatar
Ride height on all torsion bar 911's built from 1963 to 1989 is adjusted/set /determined by the torsion bars, there were some difference is shocks but they have nothing to do w/ ride height. On really low cars additional steps such as raising the spindles and lowering the steering rack are done to help restore geometry lost by lowering the car too much.
Some cars came from the factory w/ Bilstein shocks stock (notable early Carreras and 930s) or as an option, Bilstein all around makes for a very desirable setup, there are several different versions of Bilstein that have been used diffing mostly in the valving that is used. A really nice touch on a Bilstein car is to have the valving custom matched to the springs and car weight, this is done at a very reasonable cost by Bilstein San Diego.
Quick Reply: Sport Shock Option for 87 g50
