911 Forum 1964-1989
Over Charging 87 Carerra
Old 08-04-2012, 05:29 PM
AirCoolBill
AirCoolBill's Avatar
Default Over Charging 87 Carerra
My low beam headlights appeared to be surging brighter which was accompanied with a seat belt warning light which has happened several times recently. A search of the threads found similar references all pointing to an over charging condition. A check of voltage with the car running indicated normal readings.
I decided to go further and brought the car to have the battery checked as a start. The battery was about 25% low in cranking capacity and during the test the a system was charging at 16+ volts. I replaced the battery and installed a plug in volt meter to monitor.
I checked the car cold for voltage which was again normal with the car running. I took the car for a 20 min drive. It was reading 14.4V during the drive with the exception of a spike to 17+V while starting from a stop. Upon returning I shut the car off and let it sit for 5-10 min. Upon restart the voltage went to 16+V and held steady. It would not be unusual to have a heat related problem with the alternator/regulator.
Give that it appears to be the original alternator/regulator I am planning to replace it based on this condition. Does anyone have any alternative thoughts on this problem.
Thanks,
Bill
Old 08-04-2012, 06:20 PM
Ed Hughes
Ed Hughes's Avatar
Sounds like a good excuse to change the alternator.
Old 08-04-2012, 07:52 PM
911 Rod
911 Rod's Avatar
Replace /rebiuld regulator, alternator and battery now.
If you go on a long trip you will boil over your battery.
Ask me how I know .....
Old 08-04-2012, 08:09 PM
wwest
wwest's Avatar
First I would check/clean/burnish all connections, both battery posts, battery ground/chassis, intertie at starter solenoid, etc.
Old 08-04-2012, 09:04 PM
vracer
vracer's Avatar
"And while you're in there" check that your present battery had a proper overflow tube. Neutralize bat. box and drain hole area.
Old 08-04-2012, 10:03 PM
tbanasiak
tbanasiak's Avatar
Replace the voltage regulator, that's the culprit. Easy DIY.
Old 08-04-2012, 11:36 PM
Ed Hughes
Ed Hughes's Avatar
If I were pulling the alt, I'd either buy a new one, or a Bosch reman. I've not heard of anyone simply replacing the VR.
Old 08-05-2012, 01:39 AM
Radcap
Radcap's Avatar
Thats me, replaced the VR went through all that trouble just to go and do it again to replace the alternator anyway. Skip the first step and save the trouble of doing it twice. Easy 1/2 day by yourself or a whole day with help....haha
Rod,
Old 08-05-2012, 05:53 AM
AirCoolBill
Apparently there is no way to know which product is in the car. It appears that it is likely the Paris Rhone. Was Bosch an OE supplier or an aftermarket replacement? Do the remanufactured units have a poor history?
Old 08-05-2012, 09:31 AM
tbanasiak
tbanasiak's Avatar
That's exactly what I did, just replaced the VR. 2 years later+ no issues.
Old 08-05-2012, 12:19 PM
dshepp806
dshepp806's Avatar
The VRs can, alone, fail.
BEST!
Doyle
Old 08-05-2012, 01:01 PM
Ed Hughes
Ed Hughes's Avatar
See post two notches up from yours.
Old 08-05-2012, 01:15 PM
vracer
vracer's Avatar
Just because 95% replace both, doesn't mean it's the wrong approach.
Old 08-05-2012, 02:52 PM
Ed Hughes
Ed Hughes's Avatar
No, it doesn't, but I also view my time as valuable. Also, every time one takes the alt out, I feel they run the risk of damaging the fan or the shroud-both somewhat delicate after so many years, and very expensive.
More of a strategic move in my opinion.
Old 08-05-2012, 03:03 PM
wwest
wwest's Avatar
After such a long period of time in a vehiclar engine compartment environment solid-state devices(***) have only one reason, mostly, for failing.
Overstress/HEAT.
*** Bridge diode rectifiers(6), VR switching transistor.
I would say that if you discover a need to replace slip ring brushes due to wear then replace the alternator assembly in whole.
Quick Reply: Over Charging 87 Carerra
