911 Forum 1964-1989
Weight Watchers
Old 10-30-2012, 10:37 PM
Reiver
Reiver's Avatar
Default Weight Watchers
I've gotten my '83 SC down to 2528 lbs without any serious exterior body mods...that is wet.
Anyone here worked on the same issue...I'd like to email/talk off line about any techniques to go further to include bumper replacement etc.
Light = fast.
Old 10-31-2012, 12:42 AM
ivangene
Parts Specialist
ivangene's Avatar
tell us what you did so far - stock seats weigh a ton - that's an easy savings.
Old 10-31-2012, 01:05 AM
Amber Gramps
Amber Gramps's Avatar
AC delete, rear seat delete, **** carpet delete, door handle delete, giant steering wheel delete. Already had a manual top.....what's next???
Old 10-31-2012, 07:42 AM
SiberianDVM
SiberianDVM's Avatar
On my Targa: rear seat delete, rear deck delete, underlayment delete (that was at least 100 lbs right there), A/C delete, spare tire and jack delete, carpet delete. Seats are next when I find some race seats I can afford.
But I'm making most of that back up with a 6 point roll cage.
Old 10-31-2012, 09:16 AM
ivangene
Parts Specialist
ivangene's Avatar
do you have a cage yet?
I have one in the garage I am thinking of NOT installing
Old 10-31-2012, 12:35 PM
Reiver
Reiver's Avatar
AC delete complete to include all hoses, mounts, condensors etc.took the heavy sound deadning pads off of the rear deck/back seat area and replaced with very lightweight foam/foil. Removed center console. Replaced flag mirrors with vitaloni (mirrors weigh about 7 lbs)...back seat/&seat belts deleted. Removed spare tire/jack and related tools (replaced with a GM air/fix flat pump stored in smugglers box- mosy GM cars come sans spare ..pump works without jacking car up) Optima battery, lightweight pad in engine bay, no cat converter/shield...Recaro seats (cloth older light models)....and some other things I've forgotten.
RS door panels soon and momo wheel (for looks not weight).
Old 10-31-2012, 12:59 PM
ivangene
Parts Specialist
ivangene's Avatar
the momo wheel not only will look cool but FEEL fast
its amazing how it changes the feel of the car - more go-kart like
350mm is a good size
Old 10-31-2012, 01:02 PM
Reiver
Reiver's Avatar
I'm thinking the M 69 in 350...I like the fatter wheel 'feel' with the finger grooves.
Old 10-31-2012, 04:20 PM
SiberianDVM
Yes, I bought a used Safety Devices cage from another Rennlister. Saturday, I'm picking up a used Millermatic so I can weld in the mounting plates.
I've never welded before, but how hard can it be?
On second thought, maybe I'd better practice on an old wheelbarrow or something.
Old 10-31-2012, 05:50 PM
911 Rod
911 Rod's Avatar
I've heard that the spare is an important part for crash impact?
Old 10-31-2012, 05:54 PM
Amber Gramps
Love the vitaloni mirrors, but no can do in a cab. I'm already blind enough to my right.
What's the spare weigh? My wife would love the space up there. She says it's cramped up there during long drives.
Old 10-31-2012, 06:58 PM
g-50cab
g-50cab's Avatar
http://forums.pelicanparts.com/porsc...ild-story.html
everything you need to know about weight loss
Old 10-31-2012, 07:20 PM
Reiver
Reiver's Avatar
You can find it on the above Pelican...I've been using his suggestions and weights but have always weighed my own parts.
The spare/jack etc is a good loss by itself and it does make room.
Old 10-31-2012, 07:23 PM
Reiver
Reiver's Avatar
spare is 34 lbs and jack is 5 lbs. The GM fixflat/compressor is a neat deal . I found one on Amazon for 55 bucks new...works fine once you fix your lighter recep to US size and that needs doing for any device you might use.
Old 11-18-2012, 03:30 PM
Reiver
Reiver's Avatar
Ok, funny easy weight loss.....I never use the windshield washers but they do work....wondered how much fluid was in that huge wheel well res. Suctioned it out with my oil evacuator.
17.5 pounds of fluid...obviously Ferry didn't want you to go dry.
That and the heat backdate and some minors stuff has me at 2490 lbs and yup, you can feel the dif greatly on accel.
