1988 Turn Signal Assembly Help
My passenger side front turn signal was intermittent. So, I took a look and found that the bulb was loose. The spring behind the reflector assembly had come loose. I took the reflector assembly out to examine.
All of the pieces appear to be there, but I'm not sure what should hold the spring in place in the back of the assembly. There is a hex-shaped washer that looks like it would hold the spring, but there is nothing to hold the washer to the assembly. I'm wondering if something broke off of the assembly casting itself.
The bottom line is that I cannot get the assembly back into the turn signal housing without the spring falling back out. Is there a trick I am missing, or is there something wrong with the reflector assembly?
Todd
Todd
Not quite sure here, but would guess that the hex-washer would be retained by the several vertical tabs, as they would be bent "inward" at their tips so that hex-washer stays put,..
At least, that's what it looks to be from here, but we're driniking some very old Scotch this afternoon....
BEST!
Doyle
BEST!
Doyle
Todd
Another option would be to attempt an "attachment" approach with JB Weld, or whatever would hold down there...I've read where someone successfully did that....
New is always a great fix, eh?
BEST!
Doyle
BEST!
Doyle
