911 Forum 1964-1989
1978 911sc Coupe LS1 Build
Old 01-19-2013, 06:38 AM
Ruf964
Ruf964's Avatar
Default 1978 911sc Coupe LS1 Build
this build is not for the purists. but will be fun. stock ls1 so i dont destroy the 915 gearbox. car is for my wife. car has 17" turbo twist replicas with michelin pilots on car. will be doing a rear coilover conversion for handling purposes not weight. has a carrera tail and will put on 993 aero mirrors. according to info on the web the 3.0 pcar motor is 440lbs. the ls1 is 400lbs. so extra weight isnt an issue. taking out the stock pcar oil tank and lines and cooler is offset by the radiator and lines being put upfront. stock the ls1 makes 350hp around 330tq. using a kevlar clutch. griffin 3core aluminum radiator, meziere electric water pump, some kep pieces, some pieces i make myself since i own a machine shop. already have all the parts, lets get this started. building 4 ls v8 911's at once
Old 01-19-2013, 12:00 PM
Ed Hughes
Ed Hughes's Avatar
Not a lot of love here for V8 conversions. The engine is a lot of what makes it a Porsche.
Same for twist wheels.
Old 01-19-2013, 01:38 PM
Amber Gramps
Amber Gramps's Avatar
Building one makes you nuts, building four puts you in direct violation of the RL TOS.
Old 01-19-2013, 02:52 PM
race911
race911's Avatar
What, specifically, is gained for "handling purposes" by replacing the rear torsion bars on one of these conversions? Considering the weight distribution will come a few points forward.
(Yes, I was peripherally involved in a couple of V8 911 conversions back in the Olden Days, like before aluminum heads.)
Old 01-19-2013, 03:00 PM
Ruf964
Ruf964's Avatar
the only gain is adjustability.
Old 01-19-2013, 03:04 PM
race911
race911's Avatar
So then it's not handing..........
Ride height? Which takes next to no time if you've got a non-frozen fastener car to work with. Not sure how you need to change it more than one time, if it doesn't come out to your satisfaction during Round One.
You move the height even 1/2", and you're at least 1/8" off on toe each side, anyway. So it's not like you're dodging the alignment.
Old 01-19-2013, 05:28 PM
Ruf964
Ruf964's Avatar
Its not a track car.
Old 01-19-2013, 05:30 PM
Ruf964
Ruf964's Avatar
it is for handling purposes, i make my own 7075 sway bars and adjustable links, my own 7075 strut braces, so more adjustability is key to me. again, not a track car.
Old 01-20-2013, 05:46 AM
Ruf964
Ruf964's Avatar
no disrespect meant, but alot of cars including torsion bar 911's are not that adjustable or not at all. gaining adjustability with a quality nitrogen coilover gains handling. at least imho. thanks for the input tho.
Old 02-22-2013, 01:45 AM
Ruf964
Ruf964's Avatar
been working on the little car for my wife a few days now. slowly gaining ground. car was originally gold, has since been painted blue. her choice, not mine. sadly shortly after the paint, it had a minor disagreement with a hailstorm, common in oklahoma.
Old 02-28-2013, 06:23 AM
Ruf964
Ruf964's Avatar
shop pic from last wk, closest front is wifes blue euro sc awaiting ls1 transplant, then the white 88 carrera of my daughters awaiting its ls1 transplant, and my blue 964 awaiting its ls7 on the lift.
Old 02-28-2013, 06:24 AM
Ruf964
Ruf964's Avatar
far back corner is my ferrari 308 gtb, in front of that is my daughters 1988 944 turbo "s".
Old 02-28-2013, 06:25 AM
Ruf964
Ruf964's Avatar
84 euro carrera
Old 02-28-2013, 06:27 AM
Ruf964
Ruf964's Avatar
wifes euro sc when we first got it. i put ghl ss headers and ghl ss mufflers on the euro carrera and the euro sc with cai on both. both otherwise were stock euro spec motors. the sc would outrun and out accelerate the carrera everytime.
Old 02-28-2013, 06:30 AM
Ruf964
Ruf964's Avatar
my 930, eventually this got a built na 3.4 twin plug motor, with nickies, ge80 cams, electromotive dual ignition, knife edged crankshaft, boat tailed block internal windage, shuffle pinned block, 50pmo's, etc etc etc... it would put down turbo hp without the lag... but it took $$$. this was the car that led to the decision that the next car or cars would be under ls power plants.
Quick Reply: 1978 911sc Coupe LS1 Build
