911 Forum 1964-1989
Mufflers Options? What do you have?
Old 09-11-2014, 10:07 PM
Bola964
Bola964's Avatar
Default Mufflers Options? What do you have?
Hi,
I'm starting a conversion on my '88 3.2 from the stock set up to a pair of no heat exchangers direct 3 to 1 exhaust system, and was wondering what is the preferred choice of mufflers.
Today I've seen (heard) a dual exhaust stainless steel from Dansk that sounded great. Maybe a bit to loud, but sweet.
Is this the way to go, or would you suggest something else?
Thanks!
Rodrigo.
Old 09-11-2014, 11:14 PM
wildcat077
wildcat077's Avatar
I've had Fabspeed mufflers and headers with my 89 when it was a 3.2 and now as well with the 3.6 transplant,the sound is not overbearing but there is some droning between 2 and 3 K rpms ...
Fabspeed is on the expensive end though,it all depends on how much you want to spend !
Cheers
Phil
Old 09-12-2014, 04:11 AM
psychoideas
psychoideas's Avatar
Mine is only a 2.7 but I have SSI's and an original muffler that I carefully took apart and modified somewhat.
Old 09-12-2014, 10:00 AM
theiceman
Team Owner
theiceman's Avatar
Received 1,048 Likes on 746 Posts
pleaase expand on the "somewhat" lol
Old 09-12-2014, 11:38 AM
Rico
Rico's Avatar
I have an 1987 3.2 with the original DME / ECU installed in my 1972.
I went with the Dansk Sport muffler, 2 in 2 out with 1-5/8" Bursch headers,
(no heat exchangers).
The sound is nice, throaty with no drone.
Old 09-12-2014, 01:09 PM
SARGEPUG
SARGEPUG's Avatar
My Fabspeed cat bypass and duel output sounds great! People "positively" comment on it all the time..........
Old 09-12-2014, 02:06 PM
Jonathon Rolstin
Jonathon Rolstin's Avatar
SSIs and Dual outlet B+B Stainless muffler. Loud but amazing. Get comments all day long.
Black car is me, sound is me:
JR
Old 09-12-2014, 03:27 PM
ricster
ricster's Avatar
3.2l with SSI and Borla with a wong chip.
Old 09-12-2014, 10:05 PM
psychoideas
It's like a maze in there!
There is actually two skins welded together.
I took some of the maze out so there's shorter distance to travel.
I blocked of the Exhaust Gas Recirculation (EGR) port as not required down here.
And I changed the exit to the right hand side of the car
Old 09-13-2014, 02:34 AM
Bola964
Bola964's Avatar
Thank you guys.
Today I saw a car with M&K mufflers 2 in, 2 out that also sounded gorgeous.
Old 10-11-2014, 11:25 AM
Trader220
Trader220's Avatar
I just ordered the M&K GT3 1 in 2 out, M&K Pre muffler and Steve Wong Chip. I'll let you know how it works and sounds.
Old 10-13-2014, 12:01 AM
jellonailer
jellonailer's Avatar
I have a Dansk 2 in 1 out on my 3.0. Sounds great
Old 10-13-2014, 01:33 AM
Reiver
Reiver's Avatar
Muffler 'likes' are almost as bad as asking what oil should you use.....
Quick Reply: Mufflers Options? What do you have?
