Running issue stumper of the week
You guys are insanely informed, which is why I love this forum. Looking for any input to help out here.
Yesterday, perfect weather in the 60's, drove my 85 911 3.2 widebody w/ 64k miles and freshish tune for 6 hours, 90% highway. Car performed perfectly, started and idled and pulled like a train every time it was asked.
At the very end of the trip (thankfully 5 miles from home!) it began 'hiccupping' at speed. Meaning, it 'skipped' very quickly... on power, no power, on power, no power, then it'd 'catch' and continue for a bit, and do it again.
Made it home w/o getting stranded. This morning, started like a champ, idled, ran 10 miles to my office without one single problem of any kind.
Questions:
1) Do fuel pump relays 'start' to go bad? Or are the all or nothing?
2) Could trash in fuel pick up have caused it? Car was low on fuel when I started my journey, filled up a few miles later, seemed fine.
Any input or long distance diagnosis out there? Really appreciate it in advance.
Questions:
That is a stumper. Fuel is usually an all or nothing issue. Sounds like it may have been some sort of electrical connection or component that was overheated from the long drive.
What kind of driving were you doing when it started sputtering?
Professor of Pending Projects
Do yourself a favor... start the car... pop the hood... remove fuse cover... wiggle the fuel pump relay... had a similar issue on the '83 SC and it was a poor connection on the fuel pump relay.
If that is not it, then also check all grounds/connections... sounds like electrical problem...
I do have to mention... I had another issue with the '83 SC and it turned out to be the distributor. The bottom of it was loose. Had to have it rebuilt. Darn thing would take out the coil...
Driving was pure highway, up and down the gears, and at the exact moment of the infraction, was doing maybe 65 or so, 5th gear. Nothing fancy.
Thank you all for your suggestions and support. Love the RL!
Wachuko, FYI, the DME relay for the 84-89 Carrera 3.2's are under the drivers seat attached to a corner of the DME ECU mounting studs, not under hood or trunk.
Given that the car was very tired and decently warm after 5 ish hours of driving by that point, a heat-related coil interference makes sense. Guess I'll get Santa to bring me a quality coil.
BTW, I have other faster, more capable road cars than the 911, but the fun factor, the sheer driver-involved feeling of the car was absolutely serene. I had flirted with selling the car, but there is nothing I could replace it with that brings that kind of smile.
Much of the joy comes from communicating with other enthusiasts like you folks. Thanks.
Here's a suggestion that some of you may find a bit weird and I have to confess that I don't understand it fully myself. However, a few years ago at a track day I had a problem where the engine would cut out under hard cornering when turning right - not left, only right. As you can imagine, I checked all sorts of things like connections, wires, etc. And I spoke to a few mechanics, one of whom is an older gentleman who has forgotten more things about engines than most of us will ever know (although he actually has a great memory). His suggestion led me to insulate the coil body from the mounting bracket with a couple of layers of electrical tape, based on the assumption that the paint of the MSD Blaster coil had worn away over time. This solved the problem beautifully and it has been fine ever since. Maybe it would work for your problem and it's a free fix.
